Just received a Samsung 1TB SATA HD.
I know size doesn't matter, but a normal format of a 1TB SATA HDD will take hours.
Are there any risks with a quick format?
Regards,
Rob
Depends on if the drive is already pre-formatted for your OS and filesystem of choice. Generally, all a Quick-Format does is blank out the directory entries and space-allocation tables while leaving the disk-structure data (track/sector IDs, etc.) alone, whereas a full format actually erases and rewrites the structure data.
Personally, I always run a full format the first time I install a drive -- I just let it run overnight.
A full format doesn't write to every sector of the drive. It reads every sector looking for any which can't be read. It then does the same thing as a quick format but marks any bad spots so they won't be used.
Modern drives use invisible (to the O/S) sector remapping. The drive is a little larger than the specified size. Each track has a few reserved sectors. When the drive detects that a sector has gone bad it automatically uses one of the alternates instead. So a new drive really should have no "visible" bad sectors.
That said, I usually do a full format anyway! LOL
A regular format scans for bad sectors while a quick format does not.
Read the rest of the story here ... http://support.microsoft.com/kb/302686
Most times with a new large drive, I just do the quick format. For a used drive of any size, I almost always use a full format.
Quick question: Use MakeMKV to convert it to a streaming format?
By fatcharlie in forum Blu-ray RippingReplies: 3Last Post: 1st Nov 2011, 18:55 -
SATA 6.0 vs. SATA 3.0
By DarrellS in forum ComputerReplies: 7Last Post: 28th May 2011, 02:33 -
how to re-anable my sata icon in win xp sp3 (sata drives not visible in DM)
By deejay.2001 in forum ComputerReplies: 7Last Post: 11th Mar 2011, 09:47 -
Is a quick video glitch from DVD recorder normal?
By moxiecat in forum DVD & Blu-ray RecordersReplies: 26Last Post: 29th Jun 2008, 18:52 -
SATA I cables and SATA II
By HatchetMan in forum ComputerReplies: 5Last Post: 4th Feb 2008, 15:06
