i have a couple video files that have the wrong default aspect ratio.. it doesnt matter which player i open them with they all try to play in a widescreen format (which distorts the picture making everything look short/fat) i can go in an over-ride the default and set the aspect ratio at 4:3 (which fixes the problem)
my question is: is there any simple utility i can use to just change the default aspect ratio so players will try to play in a 4:3 ratio instead of the incorrect 16:9. preferably something that wont re-encode the video file
And what kind of video files are these? AVI, MPG, what?
lol, yeah that was kinda important info i should have included
they are .avi using an older xvid version for the video
i just tried this utility
http://www.videohelp.com/tools/MPEG4_Modifier
and it seemed to do the trick!!!
figured i should post it so if anyone like me does a forum search (like i did) maybe they will see this one
Video plays in the wrong aspect ratio by default.
By jimminy_kriket in forum Newbie / General discussionsReplies: 2Last Post: 17th Dec 2010, 15:05 -
Best way to change aspect ratio....
By Han Solo1 in forum Video ConversionReplies: 13Last Post: 14th Oct 2010, 10:33 -
AVStoDVD: How do I make default settings for all files to aspect ratio 4:3?
By Heyjoojoo in forum Authoring (DVD)Replies: 8Last Post: 30th Aug 2010, 22:49 -
Change Aspect Ratio of .mp4 without re-encoding
By rtharagan in forum Video ConversionReplies: 9Last Post: 27th Jan 2010, 10:07 -
change aspect ratio
By zinc in forum Video ConversionReplies: 2Last Post: 23rd Jun 2007, 09:21
Statistics
Newest guides
Latest tool updates
New media comments
