I want to download/record a couple of videos that use Brightcove as the stream player, but don't know how to do it. I just downloaded WM Recorder and tried it, but it kept saying 'CANCELED' when I tried (maybe I wasn't doing it properly).
Anyone here know how download/record off of Brightcove.tv?
Help is greatly appreciated.
Results 1 to 26 of 26
brightcove looks like flash video so try instead Orbit Downloader or Replay Media Catcher.
Thanks for the help. I assume by your response that this question hasn't been asked before or you don't know a "for sure " answer?
Never heard of Brightcove before, so that's a safe assumption. Just because Brightcove is important to YOU does not mean that the entire rest of the world has heard of it, uses it, etc.Originally Posted by syracusefan1
Baldrick is pretty smart, so I'd suggest you try what he suggested and come back if it doesn't solve your problem. The fact that he is guessing does not mean that his suggestion won't work.
My response was not meant to be rude. Clearly I trust his judgment on these things, otherwise I wouldn't have posted my question here in the first place.
FWIW, Brightcove is actually becoming a huge stream player online now. Plenty of popular sites are using it.
Brightcove.tv FLV files are stored in the Temporary Internet Files folder for the current user. Windows explorer works very hard at hiding them from you. You can get at them from a Command Prompt though.
I'm not much of a computer guy. Any chance you could give me a step-by-step guideline on how I can access the files?
It's not easy to give instructions for the command prompt. It's also known as a Command Line Interpreter, or CLI for short.
Start by opening a CLI:
1) Start -> All Programs -> Accessories -> Command Prompt
That should get you a black command prompt window. The XP command prompt is pretty smart so life will be a little easier. Some of the basic commands you will use are:
DIR (directory/file listing)
CD (change directory -- navigate through folders)
COPY (copy file from source to destination)
These take command line switches which I'll explain as we go...
The default command line prompt starts you in the folder for the current user. Normally this is:
C:\Documents and Settings\USERNAME>
where USERNAME is the account you're currently logged in under. The line you will be typing on shows the current directory name. The ">" at the end is just a marker separating the prompt and what you will be typing.
2) I'm going to use upper case for things you type in but the interpreter isn't case sensitive. Also, at the end of each line you type in hit the Enter key. Type:
DIR/A
You should see a listing of files and folders. One of the folders here should be "Local Settings". This is where you need to go. The /A is important here it means show All files and folder, even hidden ones. The Local Settings folder is normally hidden so you wouldn't see it if you just typed DIR.
3) Type:
CD LOCAL SETTINGS
That will nativage you down into the "Local Settings" folder. The command line should now show the full path: "C:\Documents and Settings\USERNAME\Local Settings>"
The XP CLI is pretty smart. You don't need to type quotes around the folder names with spaces. Like:
CD "LOCAL SETTINGS"
You can also use partial names with a asterix:
CD LOC*
will work if there are no other folders that start with LOC.
4) If you type:
DIR/A
here you will see a list of folders and files including a folder called "Temporary Internet Files". You want to navigate to that folder.
5) Type:
CD TEMPOR*
You may have to include more characters of the folder name if there is another folder that matches that partial name.
At any time you can type:
CD ..
to move up on folder level.
6) Type:
DIR/A
There should be a folder called Content.IE5. I'm using IE 6, not 5. I don't know if IE7 will still use the .IE5 folder name. If not, use whatever name it uses instead.
7) Type:
CD CONTENT.IE5
The prompt line is getting very long now: "C:\Documents and Settings\USERNAME\Local Settings\Temporary Internet Files\Content.IE5>". You might want to make the window wider. You can't do this just by grabbing the edge with the mouse. Click on the little icon at the top left of the window and select Properties. Go to the Layout tab and change Screen BUffer Size and Window Size to 120 or something like that. You can increase the height of the window here or by simply dragging the bottom edge with the mouse.
8) OK, now comes that hard parts! There may be thousands of files in your temporary internet files folder. Start up IE and navigate to the web page just before the video you want to see -- the page where you click on the thumbnail to view the video. Go to IE tools section and use the options to delete the temporary internet files. Once you have done this click on the thumbnail of the video to start it playing.
9) Back at the CLI type:
DIR/A/S *.FLV
This will show the names of all FLV files in all folders down from the current location. The /A means all files, including hidden files, and all folders (Subdirectories). *.FLV means any file whos name ends in .FLV. The file will have a cryptic name and be in a cryptically named folder. A folder something like "DBJGK7LV" and a name like "212469179_1313545292_92068e8644910bc5b37c93b9a594 27232a4c599f[1].flv".
10) Navigate into that folder, type (use whatever folder name contains the FLV file you want):
CD DBJGK7LV
11) Now you are at the point where you can access the FLV file(s). The easiest thing to do is just copy them elsewhere so they can be accessed easily by explorer. Type
COPY /B *.FLV C:\
That will copy all the FLV files to the root of drive C. Note that's a backslash after the C:, not a forward slash. The /B may not be necessary but it doesn't hurt (it means consider the file a binary file, not a text file).
12) Use Explorer to rename and move the files from the root of drive C to wherever you want them.
13) If you want to get more files without having to repeat all these steps type:
CD ..
To return to the previous folder. Then go back and repeat steps 8 to 12.
Now that I've spent an hour typing up that tutorial... You'll probably find it easier to use FireFox and a plugin that allows you to save FLV files. I don't remember the name of the plugin but I know it exists...
Wow!! I really appreciate the time you took to give me detailed instruction on this man. Thanks a ton. I'll let you know if I have success tomorrow.
Seems like a lot of work! I tried one of the videos on brightcove, and WM Recorder recorded it with no fuss.
I have found that sometimes you just get that "CANCELLED" message. Usually trying one or two more times will work, if not, trying again later often works.
I have used WM Recorder for years, and have found it emminently reliable.
Here's a sample CLI session. I hilited the commands that I typed in.
Click on the image for full res.
Oh, and this doesn't seem to work for all the videos there. Some seem to be purely streamed, not cached on the hard drive.
Orbit (as mentioned earlier) works for some files from there. Use its Grab++ tool to get the URL of the FLV files.
Awesome help jagabo. You're the man!!
Semaphoric,
WM Recorder never recognized the html link and the file name for the video I wanted to download, so then I would manually put it in and that's when I got the canceled notice. What extension did you put on the file name (asf, wmv, etc.)?
I was using v11, ADA mode, with auto. It just picked the file right up. It was recorded as an .FLV file.
I also have v10.2 on my system, set to PRO mode, 'one click recording'. Often, that will pick up streams that v11 won't. I have tried to duplicate the settings form my version of v10.2 into v11, but just can't seem to get them right.
I probably use v10.2 most often, because I find it most reliable with the site I use it on most often (KBS [Korean telvision] VODs). for everything else (YouTube and that ilk), v11 works fine and is more convenient.
I wish I knew more about adjusting the settings.
You may want to have a look at The Stream Recording Forum.
Just FYI these new players and or embedding techniques do NOT store FLV files in either the cache, or the Temporary Internet folders. Which is most likely why he's asking the question in the first place. I found this thread for the very same reason. The files are NOT stored locally, and/or are encrypted somehow. And i can find no indication of an FLV file embedded in the page source.
Oh, and this also goes for MTV and MSN video as well. Can't download 'em.
FWIW Orbit Downloader works, for some but not all of the videos on Brightcove.tv.
Wonder if Brightcove.tv is simply a search and collection point for other video sites?
--dES"You can observe a lot by watching." - Yogi Bera
Orbit worked for a half dozen music videos I tried from MTV.com. It worked for many videos from MSN.com including music videos and tv episodes. I couldn't get several "biographies" from MSN.com though.
Regarding videos not being cached: Yes, it's true that some videos are purely streamed and not cached locally. But many videos are cached locally and can't be seen with Explorer (even with the hidden and system file options enabled). If you use explorer to browse your Temporary Internet Files you won't seen them. But they can be seen and copied via the Command Prompt.
When i enter Dir/A
It says VOlume in drive C is Ryan
VOlume Serial Number is A4A9-BCb3
Directory of C:\Users\Georgeboy\Local Settings
File not found
So i type in CD TEMPOR*
and says "The filename, directory, or volume label syntax is incorrect"
In Windows XP, user data is in C:\Documents and Settings\Username\...
Haven't tried it at that particular site yet, but I just upgraded Orbit from v. 2.6.5 to 2.71, and I'm wondering if anyone else is seeing this curious error: you go to download something, and it says FireFox has generated an error, with a strong recommendation to terminate the session and restart FF. Of course, doing that would lose the video. (This is not that Dr. Watson BS with the error dump, where you don't have any choice.) I've been ignoring it, to keep going and to see what happens. The video still downloads, and it seems I can continue using FF and Orbit without restarting either, and without unstable functioning of these apps. Is this message a bug ? I'm using the latest FF.Originally Posted by DesWhen in Las Vegas, don't miss the Pinball Hall of Fame Museum ( http://www.pinballmuseum.org/ ) (http://lasvegas.wikia.com/wiki/Las_V...of_Fame_Museum ) -- over 150 tables from 6+ decades of this gradually disappearing American art form.
It has not worked for me, for any that I've tried to get from Brightcove . . . so far. Orbit does not find them, or something. And I can tell you that for a number of the videos I've watched there, they definitely cross-route to some other site that hosts the file, even though it may seem that you are still visiting Brightcove. Some sneaky techniques being employed by some of these sites, but we shall prevail in the end !Originally Posted by DesWhen in Las Vegas, don't miss the Pinball Hall of Fame Museum ( http://www.pinballmuseum.org/ ) (http://lasvegas.wikia.com/wiki/Las_V...of_Fame_Museum ) -- over 150 tables from 6+ decades of this gradually disappearing American art form.
Hey, I know this thread is a few years old now. I found it by Googling "download brightcove video." The techniques described here haven't worked for me, so I think BC's technology and security have improved since this conversation started.
Also, another disclaimer.. I'm interested in saving a standard .mp4 or similar video file from Brightcove video player, not recording a stream. So I may be a little bit off-topic. But maybe if someone else finds this thread the way I did, my info will be useful for them.
I came up with a way to download a Brightcove video.
Here's what you need -
- Safari 4+ and another browser like Firefox.
- You MUST disable or uninstall Flash Player.
- Safari's "Develop" menu must be enabled.
If you've got those three things taken care of, downloading and saving a Brightcove video is easy! Check out the step-by-step tutorial on my website.
I haven't tried this on Windows. It should work, but the steps to disable Flash Player will be different. Any feedback would be greatly appreciated. Thanks!
Another necropost:
I just spent a while trying to download a podcast supplied via a Brightcove flash element.
DownloadHelper didn't see anything.
Orbit Downloader also failed.
However, URLSnooper gave me the URL of the player, and dropping that in Stream Transport finally got the stream, which it could save as an flv.
(StreamTransport couldn't play the complete HTML page properly, but it could do the flash object.)
As the audio codec was MP3, I renamed the flv to an mp3, saved it via MP3DirectCut (which resynced the frames) and I had a good MP3.Last edited by AlanHK; 19th Jul 2011 at 07:59.
Can someone please help me download this video song
http://admin.brightcove.com/viewer/u...de=transparent
In fact, i mainly want the Good quality song, i dont care about the video.
PS: Does anyone know what song is this and can lead me to the original video?
brightcove.com
By u2fan480 in forum Video StreamingReplies: 7Last Post: 22nd Oct 2009, 13:36 -
How To Record , Capture, Or Download This Flash Video From Brightcove.com
By hypnoticpimp in forum Video StreamingReplies: 1Last Post: 17th Jun 2008, 13:13 -
The Vital Message - General Fiction, download ebooks, free download, The
By spacek77u in forum DVD RippingReplies: 1Last Post: 14th May 2007, 01:29
