Hi there im newbie. Im using dvdstyler and i get the following error message.
Error executing of command: dvdauthor -o "C:\Documents and Settings\Compaq_Owner\dvd\dvd" -x "C:\Documents and Settings\Compaq_Owner\dvd\dvd\dvdauthor.xml"
What does it mean? If anybody can help me that would be great thanks alot
Results 1 to 19 of 19
Thread: DVD styler error
As a first test, try a directory without space characters like c:\temp\dvd
GUI for dvdauthor:
http://www.videohelp.com/~gfd/
Im Not sure what your wanting me to do sorry.
I got the same error when I used the program for the first timeOriginally Posted by mikeoliver1313
so I chose another folder
He borax means
1. Click on File and select Burn DVD...
2. Chose a folder which does not have spaces in them.
Note: Make sure the folder is empty (it does not have any files in it) because the files will be deleted.
i.e Chose a directory or folder that does not have spaces for Temp Directory and Save To input boxes on the burn dialogI ekil plehoediv...
What's the reverse of above?
hi i tried that and still came up with the same error message just a different folder this time
what's that folder name? does it have spaces?Originally Posted by mikeoliver1313
if doesn't than the problem is not what I thought it was. your problem could be something elseI ekil plehoediv...
this is what I have on my Burn dialog...
Temp Directory: C:\DVDVids\HipHopVids
Create an ISO image is selected
Save to: C:\DVDVids\ISOFile\hiphopdvd.iso
I don't remember what happened when I tried an option to Burn direct to DVD, so i always use one to Generate an ISO file, though this option gives an error which I can't recall right now (I think it's exactly the error you're getting).
You may ask why I'm not worried about the error when generating ISO? Because the DVD files in a folder are generated and I then take them to DVD Shrink for ISO generation, if I see a need...
Good luckI ekil plehoediv...
No good i still get the error message
Does it still give you the ff error, exactly as it is?: Error executing of command: dvdauthor -o "C:\Documents and Settings\Compaq_Owner\dvd\dvd" -x "C:\Documents and Settings\Compaq_Owner\dvd\dvd\dvdauthor.xml"Originally Posted by mikeoliver1313
If it is, your path is still wrong, otherwise, post the exact error, may be somebody who's been using the proggy for a longer time than mine would assist.
It seems my suggestion didn't work. Sorry I couldn't help you...I ekil plehoediv...
I would guess that your source clip is somehow not agreeable with dvdstyler. have you tried other MPG files (just for testing purpose)?
Can you Demux them into separate video & Audio streams and then add them to DVDstyler?
Could paste the results of the entire log into your post, instead of just the last line?
you might be right. all the music videos I used were all converted with 'any video converter', so they never gave me a problem.Originally Posted by GideonK
mikeoliver1313 try converting all vid files with the above-mentioed program and then use DVDStyler afterwardsI ekil plehoediv...
Gentlemen, I am getting the EXACT same error as the original poster and it's bothering me because I tried everything ! ! !
If I make small clips, everything will work fine, like clips under 20 minutes.
but if I have large clips, like an hour, then I get this error. It is very strange and I can not figure out how to fix this problem.
Any help would be greatly appreciated!
Probably it would be the best to ask in the dvdstyler forum:
http://sourceforge.net/forum/forum.php?forum_id=318795GUI for dvdauthor:
That forum is dead, the OP already went there and got no replies....
Someone on here should be able to figure this out.
Paste the entire error log, please. Someone may be able to glean something from it.
frame= 2313 fps=635 q=-1.0 size= 37488kB time=80.2 bitrate=3831.2kbits/s
frame= 2536 fps=606 q=-1.0 size= 40910kB time=87.6 bitrate=3823.7kbits/s
frame= 2761 fps=587 q=-1.0 size= 44404kB time=95.2 bitrate=3821.0kbits/s
frame= 2924 fps=560 q=-1.0 size= 47142kB time=100.6 bitrate=3837.3kbits/s
frame= 3120 fps=546 q=-1.0 size= 50982kB time=107.3 bitrate=3893.6kbits/s
frame= 3304 fps=530 q=-1.0 size= 54314kB time=113.4 bitrate=3924.5kbits/s
frame= 3504 fps=520 q=-1.0 size= 57674kB time=120.0 bitrate=3937.2kbits/s
frame= 3735 fps=522 q=-1.0 Lsize= 61706kB time=127.9 bitrate=3951.2kbits/s
video:57034kB audio:3901kB global headers:0kB muxing overhead 1.265361%
Generating DVD
DVDAuthor::dvdauthor, version 0.6.14.
Build options: gnugetopt iconv freetype
Send bugs to <http://www.dvdstyler.de/support.html>
INFO: Locale=English_United States.1252
INFO: Converting filenames to CP1252
INFO: dvdauthor creating VTS
WARN: First cell is not marked as a chapter in PGC 1, setting chapter flag
WARN: First cell is not marked as a chapter in PGC 2, setting chapter flag
STAT: Picking VTS 01
STAT: Processing C:\Documents and Settings\BP\dvd\dvd\menu1-0.mpg...
WARN: unknown mpeg2 aspect ratio 1
INFO: Video pts = 0.178 .. 1.045
INFO: Audio[8] pts = 0.178 .. 6.178
INFO: Audio[32] pts = 0.178 .. 0.178
STAT: VOBU 1 at 0MB, 1 PGCS
INFO: Generating VTSM with the following video attributes:
INFO: MPEG version: mpeg2
INFO: TV standard: ntsc
INFO: Aspect ratio: 4:3
INFO: Resolution: 720x480
INFO: Audio ch 0 format: mp2/2ch, 48khz 20bps
STAT: Processing C:\cotto1\VIDEO_TS\VTS_01_1.VOB...
STAT: VOBU 16 at 5MB, 5 PGCS
STAT: VOBU 32 at 10MB, 5 PGCS
STAT: VOBU 48 at 15MB, 5 PGCS
ERR: SCR moves backwards, remultiplex input.
...ERR: SCR moves backwards, remultiplex input.
This is a 'famous' dvdauthor error. Sometimes it can be solved by using another muxer. I don't know which muxer is used by dvdstyler - according to the log, I cannot recognize the output, but it seems to be another muxer, not mplex which is recommended for dvdauthor). Another idea would be to try restream for your video files.
As all video properties seem to be 100% DVD compliant, you could try my authoring application (GfD) and use the muxman engine. This has solved some dvdauthor related problems recently:
http://forum.videohelp.com/topic349074.html
http://forum.videohelp.com/topic350849.html
http://forum.videohelp.com/topic326206.htmlGUI for dvdauthor:
Hi I am new and beginner Create DVD menus now use DVD Styler, but to burn an
ISO or burned to DVD I get this error:
Generating Menu 4 of 5
Preparing
Create MPEG menu
Multiplexing subtitles (buttons) in MPEG
Running command: "spumux C: \ Temp \ DVD-tmp \ menu1-3.mpg_spumux.xml"
DVDAuthor:: spumux, version 0.6.14.
Build options: iconv freetype gnugetopt
Send to errors <http://www.dvdstyler.de/support.html>
INFO: locale = Spanish_Spain.1252
INFO: convert file names to CP1252
STAT: 0:00:00.000
INFO: PNG had 5 colors
INFO: PNG with 6 colors
INFO: Pickbuttongroups, success with 2 groups useimg = 1
ERR: Button 10 can not find the 040,505 color in group 0
Assertion Failure: DC! =- 1, the file src / image.c subgen-line 809
This application has requested the implementation of finish in an unusual way.
Please contact the support team for more information application.
Failed
Please give me a solution as soon as possible.
I really need help, I am trying to use dvdstyler for mac...I want to just make a title page for a mkv video file I have. But the burning reaches only a little then says failed and freezes at that point..
I dont Know if this might help:
Generating menus
Generating menu 1 of 1
Prepare
Create menu mpeg
Multiplexing subpictures into mpeg
Executing command: spumux -s 0 "/Users/Mohamed/Temp/dvd-tmp/menu1-0.mpg_spumux.xml"
DVDAuthor:
pumux, version 0.6.18.
Build options: gnugetopt iconv freetype fribidi
Send bugs to <dvdauthor-users@lists.sourceforge.net>
ERR: Cannot match attribute 'format' in tag 'subpictures'. Valid attributes are:
Failed
Thanks a lot for your help
Help installing DVD Styler
By Garibaldi in forum LinuxReplies: 10Last Post: 3rd Apr 2012, 19:17 -
DVD Styler Fails to Burn
By mik1 in forum Authoring (DVD)Replies: 1Last Post: 10th Jun 2010, 01:57 -
New dvd styler error.
By mikeoliver1313 in forum Authoring (DVD)Replies: 2Last Post: 21st May 2008, 08:51 -
Final video looks intrelaced from DVD Styler
By PlayWithFire in forum Authoring (DVD)Replies: 4Last Post: 17th Nov 2007, 03:05 -
DVD Styler problem
By bennyboy371 in forum Authoring (DVD)Replies: 1Last Post: 24th Jul 2007, 21:01
