VideoHelp.com Forum
    I have a canon HDV camera and recorded a project with it onto a regular DV tape. I am having a hard time getting my footage onto my computer. We put the tape in a normal DV camera to try and capture it, and it said "HDV video not supported". Please help, i would prefer not to re shoot a whole day of footage, and i feel like this should be a fairly easy fix. Any help would be very appreciated, thank u.
  2. Member Soopafresh's Avatar
    Capture from the original HDV camera.
    did you try fast forwarding a little to skip over any HD footage that may be left over on the tape? otherwise it sounds like it may have been shot in HD by mistake.
    Would i still use capture settings that i would if it were and HDV cam? Final Cut seems to recognize the cam, but no image shows up. Thank u guys
  5. Member edDV's Avatar
    Restate your problem with specifics.
    Which Canon HD Camcorder?
    Did you shoot in HDV or DV mode?
    Do you want to edit in HDV or DV format?
    Does your Mac support HDV format? What software? Which version?
    http://www.kiva.org/about
    You can't play back HDV on a DV-only camcorder.
  7. Member edDV's Avatar
    You can read his original post several ways. He has a Canon HDV camcorder but we don't know if he was trying to shoot in HDV or DV mode. Even if he shot HDV, the Canon camcorder can transfer it as either HDV or DV format depending on camcorder settings. If shot DV format, it should play in a regular DV camcorder and transfer. If shot HDV it won't play at all in a normal DV camcorder.
  1. CS 5.5.2 fails to export HDV footage to tape/perplexed
    By Canon GL-2 Guy in forum Newbie / General discussions
    Last Post: 19th Apr 2012, 21:41
  2. Have Canon HDV A1 footage to convert to SD
    Last Post: 1st Jul 2010, 12:13
  3. Producing DVDs from HDV footage
    By lasereyes in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 1st Mar 2009, 17:25
  4. Footage shot in DV mode on an HD camera. Help
    By lafsunlmtd in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 6th Sep 2007, 16:11
  5. Replies: 7
    Last Post: 15th May 2007, 09:10
