VideoHelp.com Forum
    Hi,
    I have been trying to covert to an MP4 video format that will play on my blackberry 8310 Curve. I have been using TMPGEnc 4.0 XPress and while it works I have been having terrible problems with audio sync. The original file is in perfect sync, but when I convert it the audio and video are off 10 seconds or more. The video is also jerky and/or slow at times.
    Any Ideas as to what could be the problem.
    Thanks,
    Vachoen
    Can you post the details of the mp4, like video and audio codec and video framerate. Use MediaInfo.
    I would try convert with something else like WinFF (if you can't convert to any blackberry format directly convert to avi and then convert it with tmpgenc xpress).
    Hi Baldrick,
    Here is the info you requested.
    Format : MPEG-4
    Format/Info : ISO 14496-1 Base Media
    Format/Family : MPEG-4
    File size : 19.0 MiB
    PlayTime : 4mn 16s
    Bit rate : 622 Kbps
    StreamSize : 91.9 KiB
    Video #0
    Codec : MPEG-4 Visual
    Codec profile : Simple Streaming Video Profile/Level 3
    Codec settings/BVOP : Yes
    Codec settings/QPel : No
    Codec settings/GMC : 0
    Codec settings/Matri : Default
    PlayTime : 4mn 16s
    Bit rate : 459 Kbps
    Bit rate mode : CBR
    Width : 344 pixels
    Height : 240 pixels
    Display Aspect ratio : 1.433
    Frame rate : 29.970 fps
    Resolution : 8 bits
    Interlacement : Progressive
    Bits/(Pixel*Frame) : 0.078
    StreamSize : 14.0 MiB
    Language : ehs
    Audio #0
    Codec : AAC LC
    Codec/Info : AAC Low Complexity
    PlayTime : 4mn 16s
    Bit rate : 160 Kbps
    Bit rate mode : CBR
    Channel(s) : 2 channels
    Channel positions : L R
    Sampling rate : 48 KHz
    Resolution : 16 bits
    StreamSize : 4.90 MiB
    Language : ehs
    These video files are avi files captured directly from a Canopus ADVC 100. I will try your other suggestions as soon as I get a chance. Thanks for any help you can give me.
    Vachoen
    your using the wrong program
    try SUPER
    try these on your BB
    http://rapidshare.com/files/6553220/...tisforPorn.MP4
    http://rapidshare.com/files/5119918/...12fps-284k.3G2
    http://rapidshare.com/files/6996083/...icCurv.mp4.MP4
    your BB should support mp4 and 3g2
    Width : 344 pixels
    Height : 240 pixels
    OPPS NADA
    use 320-wide*240-tall, crop it or shrink it.. 344 will not work, its NOT QVGA , where did you get 344, AFIK the BB screen is 240 wide and 320 tall, but videos use the other orientation and its QVGA 320*240 NO 344, that won't play on the BB, even if it will play on your PC
  1. Converting video for Blackberry Storm
    By WuTangDvD in forum Portable Video
    Last Post: 7th Mar 2009, 15:51
  2. converting dvd to blackberry 8830
    By dzachau in forum DVD Ripping
    Last Post: 16th Jan 2009, 22:06
  3. Video on the Blackberry Pearl
    By Celeste in forum Portable Video
    Last Post: 19th Dec 2007, 11:08
  4. video settings for BlackBerry 8830 World Edition smartphone?
    By buzzinhornets in forum Video Conversion
    Last Post: 9th Jul 2007, 16:07
