Hi,
I am trying to use AutoMKV again. I never seem to have any luck with this program. I am trying to
convert unencrypted VOBs to WMV in order to sync with a Samsung YH-999 media player. Either it does
nothing suddenly saving a log after 30sec or it displays the following error:
Windows script host
C:\.....\mkvaudio_pip.vbs
Error 0x800700C1
So something is wrong with the audio which is AC3 6ch. It also gives this error with other DVDs.
Anyone any ideas
K109
Thread: AutoMKV audio error
please try the new 0.96 beta 12
wmv support is a little better (even if not perfect)
moreover please check that your antivirus don't block vbs script
look at doom9 thread
thanks
BHHHDConvertToX, AutoMen, AutoMKV Developer
Thanks for the quick response, I'll give the new version a go.
K109
I tried the new version. Unfortunately when I select container as WMV the program locks with
100% cpu usage. What is a container anyway ?
K109
donwload the full package 0.96beta 7 AND upgrade to beta 12
container: in simple word the kind of file resulting from muxing audios and videos, so avi, divx, mkv, ogm, mp4, wmv are all container since can "contain" audio and/or video
Still no luck. I have attached a log file. A tiny 88kb WMV file is created after a few minutes.
K109
mov001.log
your log is correct
make sure you have installed the wmv encoder (i suggest the wmfdist11.exe package)
please try with wmv7 or 8 too
enc_aacplus.dll error while using AutoMKV
By nx01rules in forum DVD RippingReplies: 3Last Post: 15th Oct 2009, 04:24 -
Automkv 0.98.4 error
By mail2tom in forum Video ConversionReplies: 0Last Post: 22nd Aug 2009, 17:40 -
convert to wmv with automkv problem,error.
By eao1 in forum Newbie / General discussionsReplies: 1Last Post: 5th Aug 2008, 19:30 -
AutoMKV getting started error?
By amdk62 in forum Video ConversionReplies: 1Last Post: 12th Jul 2007, 15:33 -
AutoMKV Error
By ^D3vIL^ in forum Newbie / General discussionsReplies: 0Last Post: 8th May 2007, 05:01
