VideoHelp.com Forum
    Hiya,
    I am new in this forum, However I use the program called Xvid4PSP, for encode .mkv files to the PSP AVC mp4 format. I got here a mkv file that contains ENG/JAP audio and subs ( ENG). So the problem is When I open this file in Xvid4PSP, I can choose which audio I want, that nice, but it doesnt seems to read the SUB at all. This could maybe be that the subs are softcoded? So my ques I need to hardcode it permanently, how ? I just dont want any modification in the other files, so the quality remain the same just how do I get the subs working( which include in the .mkv container and not as a seperate file). However I did try MKVmerge, I do see the sub and can extract it but when i try to add it in Xvid4PSP ( add subtitle), it cant read it.
    Any help?
    Thnx!
    What is subtitle format? I think mkvmerve / mkvextractgui should tell what format it is.
    If you don't know then try open the subtitle file with notepad and see if you see the subtitles then post a short example here. If it's just garble it's image subtitles.
    Hi baldrick thnx for your reply, its according to mkvmerge: ASS.
    Convert it to srt, google for ass to srt.
    So baldrick, I need to exract the sub with mkvmerge, and save it as .ass? then with a program that convert ass to .srt? thnx
    *edit : Oke I found Vobsub, but how does this works after install? I open Vobsub, I can select the .ASS file I extracted with MKVmerge, but nothing happen it wont convert or sumtin.
    when converting some ASS files, because of the features of ASS, converting to SRT isn't the best option (ie, subtitles that are used to translate a sign in a show at a 15 degree angle get dropped to a text line which can mix with other subtitles...)
    but for people who do want to try to convert ass from a mkv to srt, i use AegiSub to extract the ass from mkv, then save it as a srt, but sometimes you need to skim through the srt because it splits text oddly sometimes and/or places text on top of each other when it shouldn't [or you have special ass formats that get set as a standard subtitle]..
  1. Hardcode subs at dvd5 movie
    By Grohnheit in forum Video Conversion
    Last Post: 17th Jan 2011, 14:17
  2. Hardcode subs on .m2ts???
    By LoveMyslf in forum Video Conversion
    Last Post: 15th Sep 2010, 16:28
  3. Replies: 11
    Last Post: 27th Apr 2010, 10:04
  4. Hardcode Subs
    By Gh0st Rav3r in forum Subtitle
    Last Post: 16th Oct 2009, 16:47
  5. hardcode / burn the subs on the video
    By greendesert in forum Video Conversion
    Last Post: 20th Jul 2009, 11:55
