VideoHelp.com Forum
  1. Member gastrof's Avatar
    I'm trying to convert a .flv video to a format I can put on DVD. I tried converting to VCD, in hopes of using the .dat file to create a DVD, but the result was in 4x3 format.
    The original was in widescreen, so I don't need to tell you how bad it now looks (as in squashed).
    I don't know if I should look for other software that can make a widescreen VCD, or what.
    Is VCD always in 4x3?
  2. Banned
    Yes. OTOH, SVCD supports both 4:3 and 16:9.
  3. Member edDV's Avatar
    "NTSC" 352 x 240 pixel VCD is defined as 4:3. Pixels aren't square.
    "PAL" 352 x 288 pixel VCD is also defined as 4:3. PAL pixels aren't square either.
    Wide would be displayed as letterbox.
    Horizontally squeezed 16:9 is non-standard but many 16:9 TV sets will horizontally stretch it out to 16:9 or vertically compress it to letterbox (4:3 TV sets).
    http://www.kiva.org/about
  4. Member gastrof's Avatar
    Any suggestions on software (freeware?) that'll let me convert a widescreen .flv video to a DVD-friendly format (and preferably burn as letterbox without going to another program)?
  5. Member edDV's Avatar
    DVD is MPeg2. A program like ULead Movie Factory can author a DVD if it imports .flv. If not you will need a flv to MPeg2 transcoder.
    http://www.ulead.com/dmf/features.htm
    http://www.videohelp.com/guides?sear...or+List+Guides
    Some DVD players support divx or xvid.
  1. Aspect Ratio Help
    By darkdream787 in forum Newbie / General discussions
    Last Post: 27th Oct 2011, 02:53
  2. Replies: 0
    Last Post: 28th Feb 2011, 16:47
  3. Aspect ratio
    By ngc7088 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 11th Mar 2010, 11:25
  4. Aspect Ratio
    By jackowens in forum Video Conversion
    Last Post: 18th Mar 2009, 17:40
  5. 16:10 Aspect Ratio
    By SWBisbee in forum Newbie / General discussions
    Last Post: 31st May 2008, 01:41
