apologies if this is n the wronge forum....
i have a series of 19 short films to upload on to either blip tv preferably or if not you tube.i am having a lot of problems with exporting and conversions:
i am currently exporting as a quicktime movie/fcp doc that will play alone with quicktime pro (ie the export s quicktime movie not quicktime conversion) option.
the films are on average 2 gb (8 - 10 mins) when exported.
I am then using visualhub to encode on their settings ( i am deinterlacing in the advanced tab but thats all i'm changing) to mp4.
this leaves me with a file size of around 300 - 400 mb. the quailty is pretty good but the file size means that it takes about 5 hrs to upload to blip/you tube. -
can anyone recommend me a better format/ and appropriate settings / different program / tutorial to get the file size much smaller. i need to keep to as high quality as possible.
i ve followed the blip tv tutorials and my results were far from good.
i ve also tried to export again using visual hub , to flv format. I changed the bit rate to 400 and did not alter the size. the result was a small file but very blocky. maybe someone can advise on this?
i ve tried so many different optins now i'm going out of my head, so any help would be appreciated. thanks.
As your source file is probably DV, consider downsizing for the web (less pixels equals smaller output file), as well as using H.264/AAC .mp4 (for most quality per MB).
720x576 DV is 414720 pixels per frame.
640x352 (16:9) is 225280 pixels per frame (only 54%)
512x288 (16:9) is 147456 pixels per frame (only 36%)
Whatever huge file you have to upload, that same size will viewers have to download, so smaller sizes are very good, even if you sacrifice some detail in lower resolution. IMHO and all that.
Best file type to convert .trp for Final Cut editing
By kmxe in forum Video ConversionReplies: 2Last Post: 25th Oct 2010, 12:26 -
Query - How do i edit my Vado HD file in Final cut Pro 7
By vansep in forum MacReplies: 2Last Post: 10th Oct 2010, 12:52 -
converting hd (mts) file to final cut express 4
By ang03207 in forum Video ConversionReplies: 3Last Post: 24th Aug 2010, 00:34 -
Help with correct file format for video! Final Cut Studio
By matt_shaban in forum Newbie / General discussionsReplies: 0Last Post: 4th Jul 2009, 14:05 -
final cut express and final cut pro 6
By ednarophati in forum MacReplies: 1Last Post: 16th Jul 2007, 10:05
Statistics
Newest guides
Latest tool updates
New media comments
