VideoHelp.com Forum
    hey guys ive got a weird problem here
    i just installed a new pci ide card and my problem is when i connect 2 harddrives to it ,it will not load windows it just sits on the wndows xp boot screen but will not load but it will load if i disconnect one of the harddrives
    i bought a new psu yesterday 550watts
    i have the drivers installed and the card works fine with one harddrive connected but 2 installed and no go
    anyone got any ideas to solve this problem
    thanks for taking the time to read
    john
  2. Member edDV's Avatar
    Did you install the drivers for the card? Promise cards replace the OS disk drivers with their own. These load before Windows boots.
    http://www.kiva.org/about
    drivers are installed for the raid controller from the disc provided it says that it might not work properly until i reboot
    i then reboot and it just sitts on the windows xp boot screen with the little blue thing that scrolls across stopping and starting
    when i disconnect 1 of the harddrives ide cables doesnt matter which one it will start fine
    so it has to be something to do with the card not liking to harddrives connected of a driver issue
    please help someone
    thanks
    john
    it will only let me load with 1 harddrive installed andthe harddrive is reconised in windows
    Is one drive set as master and the other drive as slave? Or are both set at "cable select"?
    man i cant beleive i over looked the most obvious settings
    all up and running now thanks alot
  1. Replies: 16
    Last Post: 4th Jan 2010, 21:03
  2. Booting from PCI IDE
    By AuroEdge in forum Computer
    Last Post: 12th Nov 2009, 01:22
  3. Replies: 2
    Last Post: 12th Dec 2008, 14:11
  4. problem with the ati tv wonder pro pci card
    By SabbathPwns in forum Capturing
    Last Post: 7th Jul 2007, 03:21
  5. Controller card - PCI Express
    By mike909 in forum Computer
    Last Post: 5th Jun 2007, 08:34
