Hello,
I have problem w/ overscan of AVI files w/ hardsubs.
I burned test these AVI files to DivX dvd to play on my stand alone dvd player.
The TV is widescreen and the Hardsubs are cut off at the bottom.
In short of having the subs placed higher (fansub groups placing to close to the bottom)
How can I fix this problem? If possibable I’d like to keep them as AVI files to burn as Divx dvds.
Is there a way that I can convert them and fix the overscan problem?
The original file is ripped from 4:3 aspect ratio and the rip is kept as such.
video file info:
Video Codec/Container: XviD/AVI
Resolution: 720x592
Audio: 192kbps AC3
Your resolution is both too large (it is a miracle that your DVD player even played a file with a resolution above 720x576) and strange. 720x592 is 1.21 to 1, which is less than 4:3. If you are sure that this ratio is correct, I'd advise re-encoding it down to 584x480, which will bring it under NTSC DVD's max resolution of 720x480. Hopefully then your subs will be OK. If not, try using 559x460.
Capturing VHS to PC (overscan problem)
By JackDanielZ in forum CapturingReplies: 13Last Post: 18th Feb 2012, 07:31 -
Widescreen DVD menu overscan problem (only on older equipment)
By Grunberg in forum Authoring (DVD)Replies: 7Last Post: 15th May 2011, 07:39 -
ps3 overscan problem
By ieh4f in forum DVD & Blu-ray PlayersReplies: 10Last Post: 26th Oct 2008, 14:57 -
Subtitles cut off on tv. More than just overscan?
By rayden54 in forum Newbie / General discussionsReplies: 9Last Post: 13th Feb 2008, 10:20 -
Overscan, Fixing the problem without Editing the avi files?
By Gabriel87 in forum Authoring (DVD)Replies: 26Last Post: 21st Nov 2007, 19:41
Statistics
Newest guides
Latest tool updates
New media comments
