VideoHelp.com Forum
  1. I downloaded some avi files and although the quality was awesome but I noticed that there is obvious ghosting in the video. At first glance you would think the field order was switched. Can this be fixed? I would like to convert these to mpegs so I can author them to dvd.
    Who ya gonna call?
  3. Hi-
    If whoever did it left in ghosting, then he's incompetent and the quality isn't "awesome". Can it be fixed? Probably not, but we'd need a 5 second sample that shows the problem so we can have a look to be sure.
    Reversed field order doesn't cause ghosting. It causes jerky playback -- as if you took a film and reversed each pair of frames. Instead of seeing the fields in order:
    1 2 3 4 5 6 7 8
    pairs are reversed:
    2 1 4 3 6 5 8 7
  5. Member AlanHK's Avatar
    Try these filters: Ghostbuster or Exorcist
  1. Intermittent Ghosting
    By koberulz in forum Restoration
    Last Post: 27th Feb 2012, 10:14
  2. Old video card ghosting - any way to fix it?
    By Ai Haibara in forum Computer
    Last Post: 15th Feb 2011, 14:49
  3. Replies: 7
    Last Post: 6th Nov 2009, 17:35
  4. Ghosting or not?
    By mrwhitethc in forum Restoration
    Last Post: 25th Aug 2008, 11:23
  5. Curious about cause of this ghosting(?)
    By kiwiusa in forum Restoration
    Last Post: 17th Feb 2008, 21:01
