VideoHelp.com Forum
    I'm a newbie .Ok i convert a 700 mb MPEG/AVI using CUCUSOFT PRO 7 which also automatically author the file.I Then burn the dvd using nero express which take less than 5min... but for some reason it doesnt work in my dvd player. But if i use nero vision 4 to burn the dvd which take about 1.5hr it works fine.Can someone tell me why it take so long when using Nero vision. and why it doesnt work with express
    Thankx
    5 minutes is way too fast for the conversion to have worked (in my opinion) so I would suggest that it's failing and hence the DVD produced is no good
    It might be worth checking the files play (or not) before burning them. I've never used Cucusoft Pro but I'd expect some form of log to be created. Looking for/at that might shed some light on the problem(s)
    It takes 58min to do the conversion but 5 min to burn with nero Express and 1.5hr with Nero vision
  4. Member dadrab's Avatar
    Thankx
    Is it an MPEG or and AVI? Probably not both.
    I would probably use a better known encoder - i.e. CCE, Mainconcept, or one of the free ones. The one you use may be OK, but I wouldn't use it.
    Quit being is such a damn hurry. You want it fast or you want it good? Can't have both.
    Scrap Nero (for everything) and burn with IMGBurn. Burn slowly. It's not a race.
    Use good media - i.e. Verbatim.
    I'd also use a dedicated authoring engine. There are several good free ones available.
    You've taken a bunch of shortcuts and you're realizing where that'll get you. Try doing the due diligence to create a DVD the hard, long way. You may not like the process, but I'll bet you'll find out a whole lot more about making a good, viewable disc.
    READ, READ, READ. There's more knowledge here than can be comprehended by most humans, but don't be intimidated. Soak in a little more other people's processes and then create one of your own that works for you.
    I'm burning avi ,and i'll look into some of the stuff around here
  1. Do HD-BURN CD made with Nero work in DVD Players...
    By Ensign in forum Authoring (DVD)
    Last Post: 11th Sep 2009, 22:43
  2. Recording audio with Nero Vision 4 Express
    By SEE_Studios in forum Audio
    Last Post: 21st Jan 2008, 15:28
  3. Sudden problem with Nero Vision Express 3.1.0.0
    By smackyourfupa in forum Authoring (DVD)
    Last Post: 3rd Nov 2007, 16:56
  4. better tha nero vision express
    By cesarin in forum Authoring (DVD)
    Last Post: 24th Jun 2007, 13:34
  5. join and burn using winavi and nero vision express?
    By leogeo in forum Authoring (DVD)
    Last Post: 11th May 2007, 06:56
