VideoHelp.com Forum
    Hi everybody, I'm new to this forum so please bear with me.
    I have some small .MOV files which I had stupidly recorded in portrait format. Now one can only watch them putting their cheek onto the table. Trying to rotate them by 90 degrees, the only way I found so far is converting them to .AVI with RAD Tools (compressing with DivX) and rotating them with VirtualDub. This causes a considerable loss of image quality. Is there a better way, or if not, which software settings do I have to respect for best results?
    Quick Time Pro of course is said to have this functionality, but I saw several postings by dissatisfied clients.
    Any help much appreciated.
    Leo
    You could use avidemux, with x264 video
    Your final image quality will be dependent on 1) your source quality 2) settings you use to encode
  3. Other...
    Try to use... latest VirtualDub with QuickTime input plugin.
    Ater set rotate filter, choose and configure video and audio codecs.
    Try Xvid video codec, but with default Target quantizer: 4.00 (or less, example 2.00).
    Or 'high' Target bitrate - 2500 kbps or more.
    BTW
    Good to use Avidemux too (but with some exceptions - not all QT codecs supported).
    Other...
    The KMPlayer, SMPlayer and VLC media player have options for rotate video.
    Thank you. Downloaded it and will look into it ASAP.
    Yes, and 2) is where I need all posssible newbie help. Are there articles/white papers to find somewhere?
    regards Leo
    Tried in vain to find this input plugin. Any links?
    Will have to learn how to do this. ;o)
    Thank you for all your advice.
    regards Leo
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    Click on virtualdub...the mov, mp4 plugin.
  7. Originally Posted by Leo48
    Simple. :wink:
    Video > Filters > Add... > rotate (left or right)
    In Avidemux: (video) Filters > Transform > Rotate (90 or 270 degrees)
    And if You use MPEG-4 ASP (Xvid4) look at (video Configure) Encoding type: Same Quantizer as Input.
  1. mencoder wont convert the complete file, mov to avi|mov
    By bjornieB in forum Video Conversion
    Last Post: 19th Nov 2009, 07:42
  2. How to rotate a MOV file? I just gave up.
    By Pixelrage in forum Editing
    Last Post: 28th Oct 2009, 22:30
  3. Rotate Video file from iPhone
    By alexs77 in forum Editing
    Last Post: 31st Jul 2009, 16:13
  4. Lossless rotate of MJPEG file?
    By kmlee in forum Video Conversion
    Last Post: 10th Oct 2008, 18:54
  5. Need freeware software to rotate avi file.
    By Confused Chimp in forum Editing
    Last Post: 9th Jan 2008, 12:47
