  1. Hi, everybody!
    I have a video file, it has black borders on top and bottom of the screen and I'd like to know if there is an way to crop that black borders without reencoding.
    Any solution using VirtualDub, VirtualDubMod or AviDemux. I don't like to use AviSynth, well, I don't like to program a video file, write lines, you know. :P
    Or some way to crop that black borders without losing the quality of the video file.
    The video file has 544x320 of resolution, xVid codec and mp3 audio and I will crop it to 544x226.
    Thanx and my best regards. []'s
  2. Member olyteddy's Avatar
    Dec 2005
    You'll have to reencode to crop the file. You could probably crop while watching it using VLC player, but that doesn't crop the file.
    Try MPEG Streamclip. Might be possible.
    Apr 2004
    Miskatonic U
    Not possible with any software. If you crop or alter the resolution, you have to re-encode.
    Read my blog here.
  5. Originally Posted by BlooderButcher
    Watch it on TV? If they're small borders you won't see them. Oh, nevermind, I see they're big letterbox bars.
  6. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    You DO have to re-encode.
    If you want to try that, in VirtualDub:
    Video/Filters/Add
    Choose "Null transform"
    Click "Cropping..." button
    Adjust your crops by dragging.
    Then File, Save as, and choose a compression method and level -- this is the re-encoding part.
    If you choose a similar or slightly better compression than the original, the quality loss shouldn't be bad. Just try a short segment and see.
  7. Originally Posted by AlanHK
    Video/Filters/Add
    Yeah, in fact this is my method too, sometimes when I see the resulting video will be blocked or will lose some quality I use MSU SmartDeblocking video filter and the Sharpen filter to enhance the edges, you know.
    As I'm not a regular member, In fact I ask about two, three questions by year. The guides and the search function of this forum help me a lot. I only ask when I can't find an answer.
    I need to say.. Thanks guys, see ya!!!
