VideoHelp.com Forum
  1. I am trying to convert an H264 Mov file that was encoded with ALAC audio (from Final Cut) to a DVD. The video works fine, but the audio does not. I used TMPGENC, it output a wav file with no sound. I tried SUPER with no luck and MPEG Streamclip. Unfortunately I can't re-export from Final Cut right now.
    Does anyone know how I can get the audio from this file into a WAV?
    thanks,
    brandon
  2. Banned
    You might try YAMB to extract the ALAC track,
    then use dBpowerAmp for converting the .ALAC into a .WAV.
    There exists an alac.exe as well.
    HTH.
    P.S.: It seems ffmpeg and/or mencoder too can decode Apple Lossless Audio.
  3. Thanks for the help. I extracted the alac track, however, dBpowerAmp won't open .alac files (not an option under file types). I tried renaming to .aac or .mp4 and got errors.
    faad.exe from rarewares gives me "error maximum number of scalefactor bands exceeded"
    I wasn't sure how to use ffmpeg or mencoder to do it
  4. Banned
    These additional codecs are required:
    http://www.dbpoweramp.com/codec-central-m4a.htm
    (apologies for not having been clear enough) =^.^=
    [C:\]
    =>alac
    Usage: alac [options] [--] file
    Decompresses the ALAC file specified
    Options:
      -f output.wav     outputs the decompressed data to the
                        specified file, in WAV format. Default
                        is stdout.
      -r                write output as raw PCM data. Default
                        is in WAV format.
      -v                verbose output.
      -t                test that file is ALAC, also tests for
                        other m4a file types.
    alac.exe.zip
  5. Banned
    Another method: copy the plugin "alac.w5s" into the subdirectory "System"
    of your Winamp folder, drag the alac~ed MP4/M4A onto the playlist window,
    send it to "Format Converter".
    alac.w5s.zip
  6. Banned
    maestro had written:
    Me either
    mplayer  input.m4a -ao pcm:waveheader:file=output.wav
    ffmpeg -i input.m4a output.wav
    HTH.
  1. iPhone MOV to H264 AVI
    By kr1ge in forum Video Conversion
    Last Post: 15th Sep 2010, 10:49
  2. how to cut a h264 .mov file without recode it ?
    By Michael REMY in forum Editing
    Last Post: 26th Aug 2010, 08:36
  3. AVI to H264 Mov ?
    By swiftor in forum Video Conversion
    Last Post: 29th Mar 2009, 13:21
  4. Mov h264 to MP4/h264 Conversion
    By Scooter_NJ in forum Video Conversion
    Last Post: 26th Mar 2009, 10:07
  5. h264 .mov to h264 .?
    By btmdan in forum ffmpegX general discussion
    Last Post: 6th Nov 2008, 19:54
