Hello everyone.
I had downloaded an avi movie and wanted to convert it to a DVD format. I had used AVI2DVD to convert the AVI file to DVD files. Then using DVD Fab to burn it to a DVD. The reason it won't play in our DVD Player is because its a PAL type of DVD. Can anyone suggest how to convert the DVD to NTSC ?
Many thanks.
Thread: DVD player won't play movie
you could try using the free version of convertxtodvd on the avi. just make sure to set up the output as ntsc in the options menu.
once it's encoded to pal dvd it isn't easy to change to ntsc, re-encoding the avi is a better way.--
I just found an article on this same site on how to convert pal to ntsc. Will give it a go. thanks
Thanks aedipuss will give it a try now. Sorry for the late reply.
Thanks this program works like a charm despite having a water mark being the trial version.Originally Posted by aedipuss
That watermark would be why the suggestion to use the free version not the trial version.
Look for this section on the page for convertxtodvd for teh free version.
Other info:
Download the old free DivXtoDVD 0.5.2 here.
dvd player won't play movie maker cd..helpppppp!
By misispear in forum Authoring (VCD/SVCD)Replies: 5Last Post: 19th Dec 2012, 16:43 -
Why Won't it Play on my DVD Player?
By mreccentric in forum DVD & Blu-ray PlayersReplies: 9Last Post: 5th Mar 2012, 10:46 -
DVD player won´t play converted .avi
By dexter30 in forum Video ConversionReplies: 4Last Post: 10th Dec 2010, 15:59 -
dvd won't play on player but will on computer
By bubbadss in forum Authoring (DVD)Replies: 9Last Post: 28th Apr 2010, 02:49 -
Stand alone player won't play DVD-R
By NHLroyrocks in forum Newbie / General discussionsReplies: 5Last Post: 27th May 2007, 16:53
