VideoHelp.com Forum
    I have a question i just got a blue ray burner yesterday is there a way you can shrink the movie like you you do with dvdshrink or a way you can just copy to the hard drive and burn it later ?
    There are no DVDShrink type easy tools to shrink BluRay discs. They can be shrunk, but it's a very intensive, manual process that doesn't always work correctly. In theory you can rip them and burn them to burnable BluRay discs, but since I think all burnable discs are 25 GB and most BluRay discs are 50 GB, 1 to 1 copies aren't possible either, so all you could do is manually shrink it to fit and burn it to a new BluRay disc, losing all the menus and any extras.
  3. Member PuzZLeR's Avatar
    Well with DvD it was simple, the shrinking was a movie on a bigger disc onto a smaller one:
    DvD-9 -> DvD-5
    Blu-ray? Just a few combos are...
    50GB BD -> 25GB BD
    50GB BD -> BD-9 (AVCHD)
    50GB BD -> BD-5 (AVCHD)
    50GB BD -> DvD-9
    50GB BD -> DvD-5
    25GB BD -> BD-9 (AVCHD)
    25GB BD -> BD-5 (AVCHD)
    25GB BD -> DvD-9
    25Gb BD -> DvD-5
    ...and I didn't even mention further permutations with the 3x more codecs on blu-ray. DvD video only hosted MPEG-2. Now we can manipulate, and encode with, MPEG-2, H.264/AVC and VC-1. The latter two codecs are much more efficient, but very CPU intensive.
    Now you can see why Jman98 couldn't possibly give you the straightest answer. If you'd like to rephrase your question one of us may be able to help you better.
    Been away for a while and busy with work the last few months so I had no time for forums. My apologies for any emails I couldn't get to in time - missed you all! :-)
    You need to use TsMuxer - quality is dodgy if you don't add the appropriate files.
  5. Mod Neophyte Super Moderator redwudz's Avatar
    There is also the beta version of BD Rebuilder, which works similar to DVD Shrink, but for BD discs. tsMuxeR can also author to BD discs. But neither program is easy as Shrink, mainly because the BD structure is a bit more complex than a DVD. See 'WHAT IS' Blu-ray to the upper left on this page for information on the format.
  1. LG BH10LS30 blu ray burner, Doesnt seem to recognise blu ray media
    By john8611 in forum DVD & Blu-ray Writers
    Last Post: 5th Feb 2012, 03:58
  2. Blu-Ray Burner Question and Help Please
    By golfnut in forum DVD & Blu-ray Writers
    Last Post: 13th Sep 2010, 02:53
  3. Dumb Question - Burning Blu-Ray movie with a standard DVD-R burner?
    By toxicquack in forum Authoring (Blu-ray)
    Last Post: 18th Aug 2009, 03:59
  4. Blu Ray burner help
    By dafoe in forum DVD & Blu-ray Writers
    Last Post: 8th Apr 2009, 00:14
  5. Blu Ray burner Question
    By Nuff Said in forum Newbie / General discussions
    Last Post: 5th Jan 2009, 12:57
