VideoHelp.com Forum
    I'm trying to cut out some exact partial video from the start of a movie, not that much, just probably a few frames. I know about -ss but it's not working out too well. It seems to be 'snapping' to seconds, so it's either cutting too much or too little. Is there a way to seek to certain frames like -frames but in reverse?
  2. Get Slack disturbed1's Avatar
    You can use mplayer to create an edl, then have mencoder use that edl for encoding. Using mplayer to create the edl is easy, or if you know the frames you can just create the text file yourself.
    http://www.mplayerhq.hu/DOCS/HTML/en/edl.html
    http://www.oreillynet.com/sysadmin/b..._edit_wit.html
    Linux _is_ user-friendly. It is not ignorant-friendly and idiot-friendly.
    Unfortunately this seems to behave exactly as setting the -ss option.
  4. (sorry to resurrect, google led me to it). using -hr-edl-seek option on mencoder might help.
    There are also some other options that may be more accurate: https://spreadsheets.google.com/ccc?...3cE51Snc&hl=en
    Cheers!
  1. Replies: 12
    Last Post: 17th Aug 2011, 22:33
  2. Replies: 0
    Last Post: 18th Aug 2009, 07:55
  3. mencoder frames from a folder
    By tais in forum Video Conversion
    Last Post: 23rd Oct 2008, 03:26
  4. Inserting blank frames with logos before movie start
    By multiplex in forum Newbie / General discussions
    Last Post: 1st Oct 2008, 20:30
  5. MENCODER skips frames when dealing with MPEG-2 audio
    By zuja9 in forum Video Conversion
    Last Post: 19th May 2007, 15:12
