Does any one know how to transfer shows/content from my Directv Hd DVR to my pc? I have not attempted it yet but i'm just looking for a starting point.
Results 1 to 26 of 26
Starting point is S-Video + audio to a capture card.
http://www.kiva.org/about -
what is a capture card? i'm sorry i'm really new to all this. haha
Best thing to do is buy a standalone dvd recorder. Connect the s-video cable and the audio cables. Burn shows/content to dvd-rw. Finalize dvd-rw. Import dvd into pc, using DVD Shrink. Backup to Hard Drive Folder. If you are burning HD from Directv, use IfoAR2WS to change the AR flag to 16:9 format. Then burn the Hard Drive Folder from DVD Shrink to a blank dvd using Imgburn. Very easy and results are almost as good as the original HD feed. Reuse dvd-rw to burn new shows/content.
Otherwise, you can learn how to hack your dvr and import the feed directly into your computer and keep the original signal. But as far as I'm concerned, that's too complicated and if you make a mistake you'll mess your hd-dvr up. -
Originally Posted by justinflnyt
Internal ones are normally PCI cards that have composite video input, s-video cable, audio inputs and sometimes firewire inputs. Uses one PCI slot on the motherboard.
External ones are normally little boxes that have the same inputs as an internal one but connects to the pc via a usb cable. Normally not as good as internal cards.
If you are new to all this, buying a standalone dvd recorder is really your best bet. -
Originally Posted by mrswla
What is your budget?
What software do you intend to use for editing and DVD authoring?
Describe in detail what you want to do and we will suggest products to buy.Recommends: Kiva.org - Loans that change lives.
Originally Posted by cwb
Originally Posted by mrswlaOriginally Posted by edDV
Editing and burning is low priority - I have 2.4 Tb's of storage, so I'd prefer to feed vids and audio directly to the pc/laptop (laptop has the most ports for peripherals).
Options?
In the meantime, I'm looking for extra disks from TBone's list here, any of which I'm presuming will work? Or will disks ONLY with the same version work? -
Dazzle Video Creator Plus inhales like a Shop-Vac (see the other thread). -
The newer Panasonic DVD Recorders ... like the DMR-EZ17 ... can burn to DVD Ram disks ... quality is not bad at all. -
If editing isn't a priority, I agree a DVD recorder makes sense.
Anything more than that, mpg is not good for editing. -
I got a dvd recorder with built in hard drive I got a laptop only has a VGA connection on my laptop Im trying to play replay games off of espn360.com and record them to my dvd recorder I need help with what cable..Its got to be AVG to something since thats all I have on laptop.....
ATI capture cards ... especially the HDTV Tuner cards ... HDTV Wonder PCI and the 650 series ... they have a connection in the back for the ATI purple breakout connector ... you can use S-VHS cable and RCA audio cables for the video and audio connection.
Programs I use when I copy stuff from my Directv HR10-250 ... Cyberlink PowerDirector 8 ... or Cyberlink PowerCinema 6 ... works pretty good.
Wont be HD ... but it is one method. I've used it to copy movies from my DVD Player and my Super VHS video player VCR.
I sold a PC on Ebay and it was a ACER PC with Vista Home Premium 32bit on it ... worked fine if you were going to use it for recording TV shows from over the air.
But the customer had other intentions ... recording shows from their Satellite box .... only solution was using the analog S-VHS connection in the back.
If they had told me ahead of time I could have included a ATI purple breakout connector ... in the box ...... I did tell them where to find them on Ebay.Last edited by lacywest; 29th Jan 2010 at 15:07. Reason: typo
my laptop is a compaq CQ60-211DX can you tell me a good video card I can put in it that will do what I want
also got a new samsung 24 LCD monitor on my desktop I might could hook my dvd recorder to that. It has hdmi and DVI and component it has 2 hdmi on it
http://www.newegg.com/Product/Product.aspx?Item=N82E16824001280
this is my monitor from Newegg. The kicker is that my Desktop is a Dell Deminson E510 it only has VGA on the back nothing else so I would need a new video card for it. Those pretty much just pop in the slot and start it up I mean I dont have to go online searching for drivers or nothing right???? Now to what card. I guess just look for a video card with hdmi,S-Video,component. for a Dell E510. Do a search. -
That is actually a fully functioning LCD HDTV. It will accept the analog component outputs from your DVD recorder no problem. It will also accept the VGA output from either computer (one at a time). I have a similar Samsung 2333HD.
So, you can watch the sat tuner on the HDTV in HD over the HDMI connection while recording on the DVD recorder from the S-Video and audio connection. DVD recorder playback would be analog component to the HDTV.Recommends: Kiva.org - Loans that change lives.
thanks edDv so that is a good video caard to put in my PC to do what I want to play video off a website and record it on my dvd recorder
You would need a display card with S-Video out.
Like this one
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150390
Plus you could get a S-Video switch to select Sat or PC inputs to the DVD recorder
http://www.drillspot.com/products/414846/Philips_Accessories_and_SWV2030_17_3INPUT_S-Video_SwitcherRecommends: Kiva.org - Loans that change lives.
Stream movie from PC to Directv HD DVR
By LongAshes in forum Video Streaming DownloadingReplies: 7Last Post: 14th Feb 2010, 18:05 -
DirecTV DVR: how do I get to my computer to record to DVD?
By hyphenate in forum DVD & Blu-ray RecordersReplies: 10Last Post: 25th Dec 2009, 10:54 -
Revisiting the Directv DVR to PC issue
By BrandonB in forum CapturingReplies: 0Last Post: 9th Oct 2009, 04:32 -
Can I use DirecTV DVR at another location temporarily?
By robheb in forum Newbie / General discussionsReplies: 3Last Post: 2nd Jul 2009, 14:54 -
Transferring from a DirecTV DVR to Computer?
By Hangrumps in forum CapturingReplies: 0Last Post: 19th Dec 2008, 13:26
