It tried using the Sony CD-RW but they are still not reading on the DVP-S300. It does play commerical VCDs.
Any ideas on what to try ? Maybe a setting in CD Creator ?
PA
Results 1 to 9 of 9
I have a DVP-S300 and have not had any luck with CD-RW. I do not think the player will recognise them.
I haven't had any problems with CD-R's, and have tried several brands and even unbranded. All worked fine.
Try Mr. Write 4X CD-RW. It works on most very picky DVD players. I have tried several CD-RWs including Pinco CD-RW in mine and my friend's pciky players and Mr. Write is the only one that works 100%. Hope it works on yours.
Thanks for the suggestion. Do you know where I might be able to find some Mr Write CD-RWs ?
I friend of mine has told me, that all CD-RW's with a black/grey background (the side where the data is written) will work on Sony DVD players.
Hope that helps you.
Thanks guys. I found one: the TDK CD-R will run the DVP=S300
My results on a Sony DVP-S330.
Failed: Verbatim CDR CDRW. Sony CDR, Imation CDR.
Passed: Memorex CDRW (Grey back - thanks for the info).
I had a Sony DVP525D (changed to a Samsung 611 cause it did'nt play CD-R or MP3s)
I had no problemes with any CD-RW, tried
Vertaim, TDK, BASF (f***ed up after 5th reburn, porr quality) and all the VCDs looked fine until you have burn on them like 30 times, then even TDK started to look weird.
/Lars
Hi i have a Sony DVP-S330. My memorex cd-r use to work fine...now my imation cd-r vcd always stop at a certain point.what CD-rs and CD-rws can i buy
i know i need black and grey bottoms where can i get those from?
DVD+RWs no longer play
By Iconoclast in forum MediaReplies: 31Last Post: 26th Mar 2012, 20:59 -
Help finding DVD player+recorder that can play NTSC DVDs on PAL TVs
By kumi in forum DVD & Blu-ray PlayersReplies: 13Last Post: 30th Nov 2009, 21:33 -
Sony RDR-HXD890. DVD+/- RWs : Format Failed.
By Mr Mooney in forum DVD & Blu-ray RecordersReplies: 4Last Post: 30th Aug 2009, 05:58 -
asda Pacific 1001. Does it play DVD-RWs?
By zakrocz in forum DVD & Blu-ray PlayersReplies: 15Last Post: 3rd May 2009, 13:33 -
Archived unfinalized DVD-RWs--can i play them?
By mpmp0 in forum Newbie / General discussionsReplies: 23Last Post: 30th Aug 2008, 22:31
