VideoHelp.com Forum
    I just finished, and am very proud of the Home theater Computer I just built. It was built around the Gigabyte GA-MA69GM-S2H that has both HDMI and DVI-D and VGA outputs. I know that this will play blue ray disk. My question is I would like to build another media center using an older Gigabyte GA-MA69VM-S2 board which only has the VGA and a SVHS output. Can I still channel the blue ray signal from the computer to my TV or will I have to add an hdmi or dvi card to do it. Thanks in advance for all the advice Forgive me, I am a newbie to this.
  2. DVD Ninja budz's Avatar
    You'll need to make sure your video card is HDCP capable in order to view copy protected BLU-RAY movie discs if you're using a 1080p lcd tv. Also the computer monitor would need to be HDCP capable as well.
    You can use ANyDVD HD to get rid of HDCP.
  1. Cheapest Blue Ray Media
    By mol3000 in forum Media
    Last Post: 16th Feb 2010, 18:58
  2. New NON-Blue-Ray DVD Player or better off with WDTV Live HD Network Media?
    By tigerb in forum Newbie / General discussions
    Last Post: 3rd Nov 2009, 11:36
  3. Play blu ray m2ts file in Vista media center
    By ultraman36 in forum Software Playing
    Last Post: 10th May 2009, 05:41
  4. Can anyone recommend a Blue-Ray SATA Drive for my Media PC?
    By the_importer in forum Media Center PC / MediaCenters
    Last Post: 30th Mar 2008, 11:27
  5. blue ray blue rot
    By NICEBUD in forum Latest Video News
    Last Post: 21st Jun 2007, 12:01
