VideoHelp.com Forum
  1. I'm a MEGA Super Moderator Baldrick's Avatar
    What is MKV?
    The Matroska Multimedia Container is an open standard free Container format, a file format that can hold an unlimited number of video, audio, picture or subtitle tracks inside a single file.
    How to play MKV?
    Easiest, play with latest VLC Media Player or MPC-HC. If you want to use Windows Media Player or other directshow players like Media Player Classic install haali media splitter, ffdshow and ac3filter.
    MKV to AVI DivX/Xvid
    Use HandBrake. Or use Xvid4PSP, Super, AutoMKV, Total Video Converter, Winavi, AllToAVI.
    MKV to DVD
    Use ConvertXtoDVD. If you get problem converting to DVD directly you can try use HandBrake and then convert the AVI to DVD.
    MKV to Xbox 360 or Playstation 3
    Use GotSENT or for Playstation 3 use MKV2VOB. If those wont work reconvert using Handbrake.
    MKV to MP4
    Use GotSENT. If it wont work reconvert to MP4 using Handbrake or Xvid4PSP.
    MKV to Blu-Ray/AVCHD
    Use MultiAVCHD.
    Problems
    Slow playback
    If the MKV contain H264 or VC-1 HD video(identify the video codec in a MKV with MediaInfo) try Media Player Classic Home Cinema or latest ffdshow or Coreavc and play with Media Player Classic. If that wont help you might need a new computer or a new graphic card because High Defination H264 and VC-1 video requires a fast computer.
    The subtitles disappear when converting
    Extract the subtitles with mkvextractgui and add it manually when you convert to DVD( with for example ConvertXtoDVD) or to AVI DivX/XviD (with for example Handbrake or Xvid4psp).
    Audio sync issues when you convert
    It's probably because of VFR video and it's not easy to solve. Try latest Handbrake or Xvid4psp. If that wont work Give UP, it's not worth the trouble. If you want to play mkv on your TV then get a HTPC or media center with MKV support see http://www.mpcclub.com/ .
    Okey, no more mkv questions.
    Thanks!!
  3. Can someone help me understand MKV? I have blu-ray player and some MKV it plays and some it doesn't. I post here infos on mkv files he wants to play and one he doesn't so can someone tell me what is the crucial difference so I can convert ones it doesn't want to play so that it plays them.
    Here are the infos for ones he wants to play (they are in green color)
    Format : Matroska
    File size : 299 MiB
    Duration : 1h 27mn
    Overall bit rate : 479 Kbps
    Encoded date : UTC 2009-01-05 16:16:27
    Writing application : mkvmerge v2.4.0 ('Fumbling Towards Ecstasy') built on Oct 11 2008 20:13:15
    Writing library : libebml v0.7.7 + libmatroska v0.8.1
    Video
    Format : AVC
    Format profile : High@L2.2
    Format settings, CABAC : Yes
    Format settings, ReFrames : 8 frames
    Format settings, GOP : M=1, N=2
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 1h 27mn
    Nominal bit rate : 440 Kbps
    Width : 688 pixels
    Height : 288 pixels
    Display aspect ratio : 2.35:1
    Frame rate : 25.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.089
    Writing library : x264 core 65 r1069M ed32ad2
    Encoding settings : cabac=1 / ref=8 / deblock=1:-2:-1 / analyse=0x3:0x113 / me=umh / subme=6 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=16 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=440 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
    Language : English
    Audio
    Format : AAC
    Format profile : HE-AAC / LC
    Codec ID : A_AAC
    Duration : 1h 27mn
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz / 24.0 KHz
    Compression mode : Lossy
    Delay relative to video : 41ms
    Text
    Format : UTF-8
    Codec ID : S_TEXT/UTF8
    Codec ID/Info : UTF-8 Plain Text
    Second one that it also can play:
    Format : Matroska
    File size : 397 MiB
    Duration : 1h 30mn
    Overall bit rate : 612 Kbps
    Encoded date : UTC 2010-02-26 11:58:15
    Writing application : mkvmerge v2.5.1 ('He Wasn't There') built on Feb 22 2009 18:19:47
    Video
    Format : AVC
    Format profile : High@L4.1
    Format settings, ReFrames : 4 frames
    Duration : 1h 30mn
    Nominal bit rate : 575 Kbps
    Width : 1 280 pixels
    Height : 544 pixels
    Frame rate : 23.976 fps
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.034
    Writing library : x264 core 80 r1376M 3feaec2
    Encoding settings : cabac=1 / ref=4 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=umh / subme=5 / psy=1 / psy_rd=0.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / wpredp=2 / keyint=250 / keyint_min=25 / scenecut=40 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=575 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=50000 / vbv_bufsize=50000 / ip_ratio=1.40 / aq=1:1.00
    Audio
    Format : AAC
    Codec ID : A_AAC
    Duration : 1h 30mn
    Text
    Format : UTF-8
    Menu
    00:00:00.097 : en:00:00:00.097
    NOW here's the one my player doesn't want to play although I can watch it on computer (it's in red color):
    Format : Matroska
    File size : 348 MiB
    Duration : 54mn 51s
    Overall bit rate : 888 Kbps
    Encoded date : UTC 2010-03-22 18:48:54
    Writing application : mkvmerge v3.2.0 ('Beginnings') built on Feb 12 2010 16:46:17
    Writing library : libebml v0.7.9 + libmatroska v0.8.1
    Video
    Format : AVC
    Format profile : High@L3.1
    Format settings, ReFrames : 5 frames
    Duration : 54mn 51s
    Nominal bit rate : 852 Kbps
    Height : 720 pixels
    Display aspect ratio : 16:9
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.039
    Encoding settings : cabac=1 / ref=5 / deblock=1:-2:-1 / analyse=0x3:0x113 / me=umh / subme=5 / psy=1 / psy_rd=0.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=16 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / wpredp=2 / keyint=250 / keyint_min=25 / scenecut=40 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=852 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=2:1.00
    Audio
    Format : AAC
    Codec ID : A_AAC
    Duration : 54mn 51s
    Language : English
    Text #1
    Format : UTF-8
    Language : English
    Text #2
    Format : UTF-8
    Language : Greek
    Text #3
    Format : UTF-8
    Language : French
    Menu
  1. MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
    By Baldrick in forum Newbie / General discussions
    Last Post: 2nd Mar 2012, 15:25
  2. Convert Mkv to Mp4 with subtitles to play on xbox 360
    By Dreemer in forum Video Conversion
    Last Post: 1st Jul 2011, 00:15
  3. MKV to Xbox 360
    By dbanga in forum Newbie / General discussions
    Last Post: 16th Aug 2008, 08:32
  4. Stream MKV to Xbox 360
    By spork985 in forum Media Center PC / MediaCenters
    Last Post: 21st Jun 2008, 06:35
  5. Mkv to xbox 360
    By surfseeker in forum Video Conversion
    Last Post: 6th Nov 2007, 11:57
