which is more important, a high resolution or good compressibility when it comes to encoding a DVD to an avi file?
i want the best possible quality for my encode and just dont understand why compressibility is important. the higher the resolution used, the better the quality of the resulting avi file, right? so what does it matter if the compressibility is low?
basically what is the benefit of having an encode with a good compressibility percentage? please be gentle as i am new to this.
Hi-
I would dispute that. While the first one might be sharper, it would surely be much more artifact ridden. A final compressibility percentage below 38% is pretty low.having viewed the two avi files and comparing them, i can definitely see that the first encode is much better visually than the second encode. my question is this:
It matters quite a bit, which is why AutoGK tries to find the happy medium, even when you do silly things like take up over 300MB of a 700MB CD with AC3 audio, and force the width to 720. Juno isn't the kind of movie with a lot of surround effects the way an action film is, and the AC3 isn't really necessary when space is at a premium.so what does it matter if the compressibility is low?
Perhaps you don't know the kinds of things to look for. Try and find a scene with a lot of movement, maybe pretty hard with Juno. Pause it and start advancing a frame at a time. You might see such things as mosquito noise (lots of dots outside the "lines"). color smearing, and, worst of all, macroblocks, the colored squares indicative of too low of a bitrate.
If that's the case, do a Target Quality 1-pass encode and forget about doing a 1 CD rip with AC3 DD5.1 audio.i want the best possible quality for my encode...
By the way, the Juno DVD isn't out in the US for another couple of days. Is your source a retail DVD? And you got an NTSC version of the DVD in Germany already?
AutoGK keeps screwing up my resolution.
By mob in forum DVD RippingReplies: 5Last Post: 30th Aug 2010, 07:34 -
How to select ideal video resolution in AutoGK while ripping?
By vain in forum Newbie / General discussionsReplies: 2Last Post: 5th Nov 2009, 06:36 -
Resolution in AutoGK
By eliqush in forum Video ConversionReplies: 3Last Post: 29th Oct 2009, 06:47 -
AutoGk Stuck In Vista On Compressibility Test
By nhgawe in forum DVD RippingReplies: 4Last Post: 6th Jun 2009, 21:27 -
By tuanvn.2007 in forum DVD RippingReplies: 6Last Post: 3rd Nov 2008, 08:16
Statistics
Newest guides
Latest tool updates
New media comments
