Hello everyone!
I'f you've noticed the time on my post, it's 2:20 am and I am totally out of ideas for the problems i'm having! I'd really appreciate some help!
I've just got a brand new dvd movie and am trying to make a back up copy so that I can keep the original and never worry about it getting ruined by the kids etc!
Anyway, I have tried using DVDShrink to rip and copy it and it gets to the same section of the disk in the "analysing" process and then says
"DVD Shrink encountered an error and cannot continue
Failed to read file "E:\"
Data Error (cyclic redundancy check)"
Now, i've read some other posts on here regarding this which suggest the disk may be scratched etc, but this is brand new and i've copied older disks in worse condition than this with dvd shrink and they were fine!
So, what could be the problem? I've tried decrypting it with DVDDecrypt and that is unable to decrypt it either.
What on earth am i doing wrong?
Any help anyone can give me would be immensely appreciated!![]()
Thanks!
Justin
In the case of new DVDs, those are probably deliberate errors put there by the author to prevent you from backing up your purchased disc.
If it's legal in your country, try this tool first
https://www.videohelp.com/tools/DVDFab_Decrypter
and then use DVDShrink on the output if you want an sl disc -
DVD SHRINK and DVD DECRYPTER are no longer updated so as gl99 mentioned you'll have to use DVDFAB HD DECRYPTER to rip the files and then use DVD SHRINK. If you still encounter the same problem that new disc may have a scratch or smudge. Try cleaning the disc or your dvd drive could be failing to read discs. :wink:
Fantastic! I just did it with dvdfabdecrypter!
Thank you SOOO MUCH for your help!
Justin
Cyclic redundancy check error
By Arch3type in forum ComputerReplies: 6Last Post: 16th Jan 2011, 01:32 -
DVD Lab Pro 2.20 ERROR. Check inside!
By nick_gr in forum Authoring (DVD)Replies: 3Last Post: 28th Jul 2010, 08:54 -
panasonic self check problem
By tony blaze in forum DVD & Blu-ray RecordersReplies: 18Last Post: 13th Jul 2010, 22:57 -
MSU subtitle remover, the great lie!
By driva in forum Newbie / General discussionsReplies: 5Last Post: 27th Dec 2008, 19:37 -
Blank Check Command Error In Nero????
By steveuk200 in forum DVD & Blu-ray WritersReplies: 1Last Post: 3rd Jul 2007, 02:31
