Results 1 to 12 of 12
    Apr 2008
    I was wondering if anyone could recommend a simple way to fix an audio sync issue within a wmv file I have. The wmv file was created from a live stream, so I don't have anything but the wmv file to work with. The audio is consistently 1/2 a second early throughout the entire video. Anyone know how I can fix this without having to convert to another format?
  2. Banned
    Jun 2007
    UNREACHABLE
    AsfBin can fix that.
    Oct 2005
    Is there an alternative to asfbin? I have a wmv that is somehow 33.5 seconds out of sync. ASFbin allows for a max of 10s. How stupid is that!
  4. Originally Posted by unknownsoldierX View Post
    Did you try entering the number? (instead of using the GUI slider)
    Oct 2005
    Yes. In VLC, the audio is in perfect sync when I set it -33.500s. When I set Asfbin to -33500ms, it doesn't even get close to being in sync.
    The audio in the original is 33.5 seconds late. The resulting file from asfbin is still at least 20 seconds late.
  6. are you moving the right direction ?
    sometimes a delay is + or - depending if it's expressed as audio or video "delay" and sometimes it's expressed as a "shift"
    Oct 2005
    Yes. In VLC, setting -33.5 hastens the audio, as VLC says "(hastened)" when you add a - to the value. In asfbin, it is a delay setting, so using a negative number also hastens the audio. Seems that even though you can enter a value into asfbin, it is still limited to the range set by the bar, which is 10 seconds.
  8. Originally Posted by unknownsoldierX View Post
    Oops I didn't see that before posting above, must have been edited post . It looks like the correct direction if it's getting better
    You might be able to do it with ffmpeg using -itsoffset , but I' m not entire sure on the syntax
    It's going to look something like these examples
    http://www.kkoncepts.net/node/69
    http://forum.videohelp.com/threads/346293-Insert-Audio-Delay-With-ffmpeg
  9. Also you might try the command line asfbin version (it might not be as limited as the GUI)
    http://www.radioactivepages.com/asfbindetails.aspx#cmdline
    I think it should be
    asfbin -i input.wmv -o output.wmv -adelay -33.5
    Oct 2005
    Totally forgot that there was a CLI version of asfbin. It worked. Yay!
    Thank you!
  11. Out of curiosity - how in the world is the A/V sync more than 30secs off ? That' s huge!
    Oct 2005
    No idea. It's something I downloaded and It was just like that. Not sure how it was made.
