VideoHelp.com Forum
Results 1 to 22 of 22
  1. Have seen some similar discussions, but nothing quite like what I need. So...
    Have a number of music tracks, a vocal track, and a group of pictures. Would like to create an AVI or MKV file from all this. So need to be able to bring in several MP3 files (voice and custom music) and a number of JPEGs/PNGs. Would like to add some panning and other effects to the transitions.
    And (the killer point), I'd like to find a freeware tool that does this. End product is going to be distributed for free, so paying for the tool seems a bit overkill.
    Yes, I'm aware that Windows Movie Maker has some abilities in this area, but I have to do work on more than one computer (limited time on either system I have access to). So I'd ideally like something I could run from my USB stick.
    Thanks in advance!
  2. So is it safe for me to assume that my choices are Windows Movie Maker, or to pay for some other tool? Haven't seen a reply to this thread, and I certainly don't see anything out there that appears to be able to do this in the Tools section. Just want to make sure I'm not missing something before I get started and then find out there was an easy answer out there I was missing.
    Thanks again,
    Ewan
  3. BuskerAlley.com zoobie's Avatar
    you'll want a complete editor for all that
    you may be able to find an older version of vegas or premier, videostudio for free...
    Author, Producer, Composer, Director - Sony HDV, Konica SLR, LG BD burner
    Handcoder: HTML, PHP, JS, CSS - In Production: Busker Alley - The Movie
  4. Banned
    OR: you might ---
    1) get the free adequate tools (Avisynth&&plugins, VirtualDub, Avidemux, Wax,
    MKVtoolnix, IrfanView, dbPowerAmp, Audacity, etc-etc-etc);
    2) start learning how to use them (the guides available @ this forum
    can be a good starting point)
  5. Originally Posted by Midzuki
    OR: you might ---
    I actually have all those tools except for Wax, but am not aware of a tutorial that shows me how I would do what I am describing using them. For example, VirtualDub does not allow you to use PNG or JPG images as the inputs for the video. If you use AVIDemux to serve them up, then you need to know how long you're going to need each image ahead of time. Which means you have to time each individual track and set that as a script. And so on...
    So while I don't doubt it is POSSIBLE to do what I'd like to do using a grouping of the free tools out there, I don't see that as being an optimum situation
    Am going to do at least the first one using WMM then. It doesn't allow me to do any "in tool" mixing of audio and music tracks, and the titles and credits options are a bit limited, but it will let me put the pieces together in a somewhat intuitive fashion.
    Thanks for the ideas,
    Ewan
    Virtualdub will open both jpeg and png images. It will take a lot of work to turn each image into an avi and then put them together in a final clip but thats how movie editing works. Transition capabilities are limited with Virtualdub though.
    I have to agree with Zoobie that you want a complete editor on this one, because you will want a storyboard to overlay audio/video with a timeline & transition effects.
    You could do it all with avisynth - it's very powerful - but it's not very user friendly and you don't get instant visual results.
    Just a suggestion for part of your workflow - stills can made into video clips through the use of avisynth, here is a sample script:
    http://forum.videohelp.com/topic99389.html#still2vid
    You could make little clips from stills then feed them into wmm for example.
  8. FWIW, it took me all morning, but WMM did give me a decent product which I've just put up on YouTube. However, I do like the Avisynth suggestion, and that might be worth looking at as well.
    After having done this, I'd say my biggest problem was with being unable to do any audio editing within the video tool. IOW, there's a couple places where I would have liked to have multitrack with music softly in the background behind some voices.
    FWIW,
    Ewan
  9. BuskerAlley.com zoobie's Avatar
    congratz on making a video the way you didn't want
  10. Well, I have found something that is slightly (emphasis on the slightly) better. That is a web application called Jumpcut. It gives you most of the same controls as WMM, but since it's online you can work from any computer that has a browser, and it does let you do the same things with audio and picture clips that WMM does. It still (!) doesn't let you edit the audio clip or mix audio clips within the editor. It looks like if I want that capability I need to look at a paid option - though it's hard to tell which of the paid editors will let you do that either. Recommendations, preferably inexpensive?
  11. Have also just downloaded Pinnacle's Video Spin software. It has the right price tag, although I gather that some important functionality stops working after 15 days unless you pay $15 bucks. However, it DOES offer two audio tracks with the ability to alter the volume of the tracks independently.
    I've also started looking at the paid products out there, and that has me even more concerned. The reviews for the "prosumer" products such as Premiere Effects and the others seem to indicate that there were a lot of bugs in the latest versions of everyone's last update. Kind of scary to imaging paying $100 and then ending up using WMM (as at least one Amazon reviewer claimed) to get things out.
    Suggestions/recommendations from others in this area?
  12. Having had some time to spend with it now, I have to say I'm a bit more impressed with the VideoSpin product than I expected to be. Kind of surprised not to see it listed in the Tools section. Suppose I should go add it, eh?
    In any event, of the "larger" packages, are there any recommendations for doing the sorts of things I'm doing? Or is this about as good as it gets (or needs to get)? Am getting ready to put together the next animatic, and am looking forward to being able to have music in the background during voiceovers. Also the fact this one will be in color
  13. BuskerAlley.com zoobie's Avatar
    yikes...the last was in b & w?
    I've noticed cartoons seem to live in 15fps land
    most editors have SD down by now....and are now wrestling with HDV
    you can usually d/l demos of junior and pro versions of editors
    adobe, corel, sony, pinnacle, edius, final cut pro (mac), etc...
    ...but now that I think about it, if animation is your thing, you may want to look at flash
    www.flashkit.com/boards/
  14. Last one was mainly B&W to maintain the flavor of the original source. Now, since you obviously have good taste - living in Colorado and being a Rockies fan (I grew up in Loveland, just south of Fort Collins myself), I know that you'll like the new video
    Alpha's Cafe - Chapter 2
    Which I put together with VideoSpin, so you can see how that compares to using WMM the last time.
  15. BuskerAlley.com zoobie's Avatar
    yep...I'm above Boulder
    too bad you can't put audio to the .gif format
    you should be looking at flash which a lot of animators are using...
    this will also release more creativity with more options
    sure there's a learning curve...like anything worthwhile
    With animation, you need high resolution and high bitrate so GIF will not work. the less colors you have, the more pixelated the frames will become.
    The Disney animations look great on DVD but look horrible ripped and compressed to 700MB XviD.
  17. BuskerAlley.com zoobie's Avatar
    that last one's quality wasn't exactly smashing...
  18. Banned
    EwanG wrote:
    Needs Japanese audio ^_^
  19. Originally Posted by zoobie
    Must admit that the conversion YouTube does was not very kind to the fade out/ins. I will certainly have to avoid that in the future. Anyone else with rules of thumbs for beating the "downconversion" monster?
  20. Originally Posted by Midzuki
    In which case it would then also need subtitles and... nah, I think not. At least not for me
    First, Ewan, congrats on getting your animation done and up on youtube, nice job.
    I'm trying to do a similar project (photos, video, music, voices, some captioning), and I'd like all of it to be scripted and able to be run from the command line. Avisynth is amazing, but the learning curve is very steep. I'm sure it's simple to put a photo and video together, and merge the sound from the video with a software music background. Alas, I'm not quite sure how to do that!
    Ran across your thread while looking for avisynth examples like that, and was wondering if you were continuing to use AviSynth or if you were happy with the other software you mentioned that has a GUI.
    Again, congrats on completing your animation.
    Tac
  22. Originally Posted by tacman1123
    Been very happy with Videospin. Multiple audio tracks with independent volume control, nice transitions, etc.
  1. Replies: 0
    Last Post: 2nd May 2010, 16:17
  2. No voice audio for particular avi file
    By GLE3 in forum Software Playing
    Last Post: 12th Apr 2009, 19:12
  3. How to create an .avi file with only images and mp3?
    By RZ_29 in forum Newbie / General discussions
    Last Post: 1st Mar 2009, 11:47
  4. multiple images imbedded in a music file
    By Aaron1978 in forum Audio
    Last Post: 20th Apr 2008, 11:18
  5. How do I join JPG images to creat an AVI file
    By forensic in forum Editing
    Last Post: 15th Mar 2008, 21:23
