Which app would U recommend for my process:
I copied old VHS tapes to DVD with Sony DVD/VCR combo -
I then edited them with VideoRedo then converted all the VOBs to one MPG2 file using AVS then back to VOBs with DVDsanta -
I tried copying with out the MPG conversion but the burned DVDs did not work after editing -
The video clarity is grainy, I was hoping to get an app that will adjust video quality; pixilation sharpness, color, contrast, etc. so I can burn it back to DVD -
Also does all this multi conversion also dilute pic quality?
Please excuse my Novice approach as this my first attempt -
Which app and method would you recommend for my project -
Thanks for Your assistance
A VOB is very basically just a MPEG in a VOB container. After VideoRedo finished the editing, you should still have that same MPEG from the VOB, just edited. At some point, it sounds like you have done a unnecessary re-encode. I would go back through your process and see where it went wrong. I suspect DVD Santa.
You could also extract the MPEG from the original DVD with VOB2MPG, edit it, then re-author it to a DVD file. Unless your editor re-encodes the file, it should stay the same quality all through the process. That's the advantage of digital video.
You just need a authoring program. Freeware, try GUI for dvdauthor. Payware, TMPGEnc DVD Author would be a easy payware option.
And welcome to our forums.
BTW, Bold and colored text doesn't improve the amount of responses here, it reduces them most times.
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 15:12 -
Lossless editing of mpg2 .TS files with errors
By jd594 in forum DVB / HDTVReplies: 0Last Post: 10th Feb 2010, 10:04 -
Editing one of the .VOB files
By Yaro in forum EditingReplies: 94Last Post: 4th Sep 2009, 15:52 -
Editing .mov files and .ifo/.vob files
By redhot in forum EditingReplies: 7Last Post: 25th Nov 2008, 07:31 -
Patch resolution in .vob files
By geohei in forum Authoring (DVD)Replies: 3Last Post: 18th Jun 2008, 01:12
Statistics
Newest guides
Latest tool updates
New media comments
