VideoHelp.com Forum
Page 2 of 2
FirstFirst 1 2
Results 31 to 44 of 44
    I am having a similar problem with a realmedia file, extension .rmvb. ffmpegx can play it but has trouble converting it, and after a while it just gives up.
    process.txt
  2. Explorer Case's Avatar
    0:03:08 of output isn't much, I take it your clip was longer then?
    Yes, it's 51 minutes long. And the aborted .avi file that ffmpegx produces here is not a playable file. What I don't understand is how ffmpegX knows enough to play the file but not convert it. Any ideas? Are there big differences between Mplayer and Mencoder?
    Hello,
    I'm trying to convert a rm files... following the instructions of this post I finally export succesfully but there's errors in audio /video syncronicity.
    Here's my proce file: http://pastebin.com/f1250d9bf.
    Somebody can give me a clue?
    Thanks a lot!
  5. Duplicate frames may cause A/V synchronization errors. Duplicate frames may occur when input and output have different framerate. It seems that your file here is 25 fps (or, at least, that's the value guessed by mplayer) did you use the same value in ffmpegX ?
    Hello,
    I try all framerates possible and the result will be the same.
    I resolve my problem using RealPlayer on Win Platform and using the converter bundle comes with the RealPlayer application.
    Thanks for the help jpschuck!
    Have a nice day!
    hi.
    i can't launch any rmvb movie into ffmpegx. if i drop it or just open it in the aplication, it just stays still. i must quit the program, beacuse nothing 's hapenning. i have installed the reallib etc.
    here's the problem:
    is there anybody who can solve it?
    p.s. my mac os x version is 10.6.1.
  8. Explorer Case's Avatar
    Did you install the reallib version for Intel Macs? Because the PPC version won't work on Intel Macs.
    yes.
    hmm, that's weird. i tried another file that i want to encode, and now it's working.
    anyway, thx for fatigue.
    sh*t. now it's 'working' but it gives me an 1kb output file...? [i want to encode it to psp format]
  10. Originally Posted by rafki
    ffmpegX PSP presets use ffmpeg engine instead of mencoder (see the "video" section in the "summary" tab). ffmpeg engine is not able to handle Real media files. You will have to check the detailed settings of the PSP preset you want to use and manually set their equivalents with the "xvid mencoder" or "h264 mencoder" presets.
    ok, choosed for mpg h.264. hopes it work.
    thx for help.
    not working. if i try h264 [.mp4] it comes out as a .264 file, wich psp can't read...
    any solutions?
    Hello. I followed ALL the directions EXACTLY from:
    http://www.ffmpegx.com/download.html
    That is, I
    (1) downloaded the three codecs (mpeg2enc, mencoder, and mplayer)
    (2) ran ffmpegX and installed the codecs
    (3) downloaded the "reallib" folder from
    http://sourceforge.net/projects/mpla...b.zip/download
    and installed it in /Library/Application Support/ffmpegx/.
    But when I drag an (already-tested) rm video file onto the DROP FILE HERE, ffmpegx freezes and I have to force quit.
    I've spent 4 hours on this. Redoing it again and again, with slight modifications. For example, instead of (3) as above, I did (3) via the "Binary codec package" from http://www.mplayerhq.hu/design7/dload.html. That is, I copied the /usr/local/lib/codecs/ contents to a newly created reallib folder inside /Library/Application Support/ffmpegx/
    Can anyone help?
    That is, I
    Can anyone help?
    Like Demogorgon, I'm also facing the exact same issue. I've also download the correct binary code, renamed to realib and copied into the correct folder. However ffmpegx freezes before I could go into any options as shown in screenie. I'm using snowleopard with an old macbook, not sure if the hardware or OS is an issue...
    Macbook 2.4GHz
  1. Installed ffmpegX but not converting
    By bene07 in forum ffmpegX general discussion
    Last Post: 2nd Dec 2010, 15:42
  2. ffmpegX says it's finished converting, but nothing is produced!
    By alexliz in forum ffmpegX general discussion
    Last Post: 12th Dec 2008, 14:16
  3. Ffmpegx freezes when converting rm
    By neilaja in forum ffmpegX general discussion
    Last Post: 1st Dec 2007, 22:52
  4. Replies: 9
    Last Post: 27th Jul 2007, 16:07
  5. ffmpegX crash when converting to DVD
    By granoli in forum ffmpegX general discussion
    Last Post: 2nd Jul 2007, 18:39
