VideoHelp.com Forum
Results 1 to 9 of 9
    Hello,
    I'm trying to reencode a WMV file to AVI. The WMV file is about 100Mb, has 29.97 fps.
    I'm using AviSynth command DirectShowSource("file.wmv", fps=29.97) to open the file with VirtualDub.
    I make the following settings in VirtualDub:
    - Video -> Direct Stream Copy
    - Audio -> Source Audio, Direct Stream Copy
    When I choose to Save the file as AVI, I get a final file of 7GB (!) and that is my problem.
    I wonder where so much redundant information comes from...
    I only need a final file of same size as the original, 100Mb or a little bit less.
    If anybody knows where the problem may be, please advise.
    Thanks!
  2. Banned
    You must use the latest stable version of VirtualDub plus
    the WMV input plugin. Avisynth scripts always output
    uncompressed video and uncompressed audio, which are not
    very suitable for "Direct Stream Copy".
    http://home.comcast.net/~fcchandler/...WMV/index.html
    Thanks for the tip but I actually did that at the beginning. I'm using VirtualDub 1.7.8 with the wmv plugin and when I load any WMV file, it sais "Missing Codec", and just can't load wmv files.
    I think DirectShowSource() is OK but I think I'm missing the proper settings in VirtualDub....
  4. Banned
    Try installing the WMV9 Video Compression Manager.
    You may also need the ffdshow plugin for the proper decoding of VC-1 streams.
    http://download.microsoft.com/downlo...v9VCMsetup.exe
    Sure DirectShowSource() is OK. But it gives you uncompressed video. You will have to use VirtualDub in Fast Recompress mode (at least), select a compression codec, select the compression parameters, and then save.
    If you want to put the WMV video into an AVI file without conversion you will need a VFW based WMV codec. This, I think:
    http://www.microsoft.com/windows/win...cdownload.aspx
    OK, now I have the WMV9 Codec installed on my PC (ffdshow was from before, as part of a mega codec pack), but same result:
    can't load the wmv file directly into VirtualDub ("Missing Codec"), and
    can't get a same size AVI file by reencoding with DirectShowSource().
    If I choose Fast Recompress mode in VD, the file gets even bigger than 7Gb!
    No matter how RAW the video is, one thing is for sure: if you get a bigger size file after any kind of processing, reencoding, etc, than that extra information in the new file is redundant.
    Very strange piece of software..
  7. Banned
    Are you sure you're not dealing with an "Advanced Profile"
    Windows Media Video 9 File (also known as "VC-1")
    Did you enable the VFW WMV (and VC-1) decoders in ffdshow? VirtualDub uses VFW not DirectShow. Start -> All Programs -> ffdshow -> VFW Configuration.
    You didn't select a video codec to compress the video. Video -> Compression...
    Note that AVI is a container -- a box you put video and audio in. That box can contain video and audio compressed (or not) with any of a zillion different codecs.
  9. Always Watching guns1inger's Avatar
    Fast Recompress simply passes the video through to the codec you choose without affecting the colour space. The normal behaviour of virtualdub in full processing mode is to convert the colourspace to RGB, which is slow to process. Fast Recompress simply bypasses this stage (and means no filtering), but you still have to chose a compression method (codec).
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  1. WMV to Avi(xvid,mp3) using VirtualDub - huge destination file
    By chm in forum Newbie / General discussions
    Last Post: 20th May 2010, 17:29
  2. VBR (Variable Bitrate) WMV file to avi conversion process problem...
    By Atakanbasturk in forum Newbie / General discussions
    Last Post: 31st Oct 2009, 16:44
  3. 2 Small-ish AVI -> 1 Larger AVI = HUGE File. Why?
    By cxp36 in forum Newbie / General discussions
    Last Post: 6th Mar 2008, 17:31
  4. wmv to avi (divx/xvid) conversion jumpy output file
    By famine99 in forum Video Conversion
    Last Post: 14th Oct 2007, 11:09
  5. wmv to avi (divx/xvid) conversion jumpy output file
    Last Post: 11th Oct 2007, 21:04
