VideoHelp.com Forum
Results 1 to 9 of 9
    I am lost. I have been trying to figure this out for days. I have several Hi8 tapes that were recorded with my Sharp VL-AH30 Viewcam. I want to either covert them to DVD or somehow store them on my PC for editing. I am running VISTA and I have installed a WinTV-HVR-1800 to use with Media Center. It works fine for viewing and recording live TV with in Media Center.
    The camera only has the single Audio/Video output that splits to one Audio and one Video RCA jacks. I have the audio split into two and connected to the audio input on the back of the card. I have the video ran through a RCA to S-Video converter and then connected through the S-Video input on the card. How do I capture the Stream? Windows Movie Maker does not allow you to capture analogue. I also have CyberLink Power Director and Power Producer that I use with my JVC Everio. The version I have is not totally compatible with VISTA and the upgrade is about $50. I can’t seem to get anything to view the stream. What is the best way to proceed?
    Thanks for your help.
    Rot
    Use the software (WinTV2000?) that comes with the HVR-1800. Press the little green button between the channel up/down buttons to cycle through inputs.
    When i try to install, it give me the following:
    Well I was finally able to get WinTV to work, but only have downloading v6. I figured out how to get it to recognize my video input. I have sound, but no picture. Any suggestions? As I stated earlier, it works fine with Media Center. Is there some sort of conflict? Please advise.
    Rot
    I suppose you did this:
    http://www.hauppauge.com/site/suppor....html#external
    Except the reference to Pal-BGHIDK is obviously not right for the USA. There should be an NTSC_M setting or similar.
    I was finally able to get it to work. I had to use drives from mce_cd_v32 and WinTV v6 from hauppauge_cd_3.4d1. I get good picture but occasionally the picture jumps or distorts. Any suggestion for improving the image quality?
  7. BuskerAlley.com zoobie's Avatar
    see if you can rent a TBC to stick in there if it's really important
    Author, Producer, Composer, Director - Sony HDV, Konica SLR, LG BD burner
    Handcoder: HTML, PHP, JS, CSS - In Production: Busker Alley - The Movie
    Where would you rent one of thoes?
  1. Hauppaugr WinTV-HVR-1800 IR Remote trouble
    By agoramilio in forum Media Center PC / MediaCenters
    Last Post: 21st Nov 2009, 08:36
  2. WinTV HVR 1800/1850 - interlaced capturing?
    By justin81 in forum Capturing
    Last Post: 10th Jul 2009, 10:13
  3. Replies: 5
    Last Post: 6th Jul 2009, 14:46
  4. Hauppauge WinTV HVR-1800 Jerky unless recording
    By michaeldg1 in forum DVB / HDTV
    Last Post: 6th Apr 2009, 15:10
  5. HVR-1800
    By cathudog in forum Media Center PC / MediaCenters
    Last Post: 14th Jan 2008, 18:10
