i am trying to create a menu using dvd architect by sony. when i try to import media into the program it says that i need to change the file types. the media is in avi format and dvd architect mainly suports mpeg. is there a program or way to change the avi file into mpeg? also is there any free downloadable tutorials for DVD Architect?
Thread: DVD architect
DVD Architect is a DVD Authoring tool, and requires DVD compliant files.You can read about these in What is DVD (top left corner of this page). Normally DVD Architect comes with Sony Vegas, which will convert most formats to DVD compliant mpeg-2 video and AC3 audio.
However Vegas does not like Divx or Xvid, so if your source is downloaded videos, you might try converting with FAVC first, then demuxing the results so you can author with DVD Architect.
well i downloaded some movies and i just want to create a menu where i can choose witch movie to play instead of skipping through all the movies
If you don't convert to DVD format MPeg2, it won't be a Video DVD or play in a DVD player.
The whole point of DVD Architect is to make an in spec Video DVD.
What is DVD?
http://www.videohelp.com/dvdRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Use FAVC. It will convert your movies and give you a menu. Of course, once converted you can only put 2 - 3 hours of medium quality on a disc.
sony dvd architect ?
By Deter in forum Authoring (DVD)Replies: 7Last Post: 26th Jan 2010, 17:31 -
DVD Architect 5.0
By Mr. Robinson in forum Authoring (DVD)Replies: 1Last Post: 4th Nov 2009, 10:59 -
dvd architect and TMPgenc plus
By rikit in forum Newbie / General discussionsReplies: 2Last Post: 5th Aug 2008, 21:23 -
DVD Architect help
By monks19 in forum Authoring (DVD)Replies: 11Last Post: 23rd Aug 2007, 06:46 -
DVD architect
By Abiyad in forum EditingReplies: 1Last Post: 19th May 2007, 08:02
