good day! just tried burning data only on a dual layer disc...it was successful though...my inquiry is: after burning, I tried inserting the disc on the dvd burner ( ASUS 2014L1} i used to burn it. but unfortunately nothing happens....dvd writer cannot read the disc....by the way i'm using NERO 7 ESSENTIALS....any info or help will be highly appreciated.....
thanks and more power!
eckoviscon
First, never use Nero to burn DL discs, it just doesn't work that well. Use ImgBurn instead and only use Verbatim DL media if you want to have consistent results. Nothing else works as well. That said, DL data discs should work with other media brands, but it's not worth the bother if you make coasters. Stick with Verbatim.
Second, it's not unusual that the burner that made the discs can't read them. That's not a true test that the disc is the problem. Try playing it on a set top player or a different DVD drive. If it still fails, then Nero or your media brand may be the problem.
thank you so much for the info .....really appreciate it....good day!
Okay I have burned a dual layer dvd, and it will play on all my standalone dvd players; however, it will not play on any of my dvd drives connected through my computer, blu-ray drive, hd-dvd drive, the dual layer drive i burnt it with, any suggestions, and no i did not use nero, i used convertxtodvd
ok the dual layers will also work on the single layer dvd rom drives, just not the dual layer dvd rom drives, makes logical sense......(sarcasm)
Dual layer disc error (2nd layer not burning properly - AVCHD)
By hhhgamewmx7 in forum Authoring (DVD)Replies: 7Last Post: 24th Aug 2008, 10:00 -
8.5G Dual Layer DVD data size capacity in megabytes
By llee782 in forum MacReplies: 2Last Post: 19th Nov 2006, 15:42 -
hp dvd 740 will not burn a dual layer disc
By darkangelman1 in forum DVD & Blu-ray WritersReplies: 9Last Post: 1st Jun 2006, 17:20 -
Mitsubishi DVD-R (data) dual layer media not recognised
By dastott in forum MediaReplies: 2Last Post: 27th Dec 2005, 07:40 -
DVD to a dual layer disc, will it be as simple as that?
By dead_indian_walking in forum DVD RippingReplies: 3Last Post: 19th Apr 2004, 14:19
