After ripping Blu Ray to my hard drive, how do I burn it to my Blu Ray Burner?
Results 1 to 13 of 13
Ppurdue,
Have you tried the "Blu-Ray to Blu-Ray" section on the forums? It might be worth it.
CAL
D-Mak
There's nothing specific to burning Blu Ray after ripping it in (Blu Ray to Blu Ray).
You can rip it but not burn it?
Nero as UDF 2.50
or
ImgBurnRegards,
Rob
Post anything regarding blu-ray ripping to blu-ray in our blu-ray to blu-ray forum. Moving you.
Rob
Thanks for your input. I know you can record streams for playback on your computer, but how about disks
that can be played on a stand alone blu ray player?
As above.
Regards,
Rob
Rob,
Thanks again for the input. Is there a good authoring or shrink program to go with that?
No shrink program - you have to re-encode if you want to make the movie smaller.
To author, try TsRemux and output to Blu-Ray.Regards,
Rob
i used anydvd hd to rip one of my blu-ray movies to my hdd and would like to know exactly what settings to use with tsmuxer because I tried the blu-ray output, selected the m2ts file 0001 which was the largest in the stream folder but once it completed it was the same size...about 31gb...I need to get this down to burn on regular 25gb blu-ray disk or any other media without compromising its quality.
Select only the video and one ac3 audio. Next cut about 3 min off the end. Good Luck.
Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
By brad350 in forum Newbie / General discussionsReplies: 10Last Post: 21st Apr 2012, 04:15 -
M2TS, AVCHD, BLU RAY Playback Problem on Sony Blu Ray Players
By messi magician in forum Authoring (Blu-ray)Replies: 11Last Post: 15th Jan 2012, 18:25 -
Wanna convert Blu Ray Movie to Play on Laptop/PC without a Blu Ray PLayer !
By augustya in forum Blu-ray RippingReplies: 5Last Post: 13th Aug 2011, 03:35 -
Introducing Ray in Blu Rendr - Digital Media Receiver Blu-ray Disc
By rayinblu in forum Newbie / General discussionsReplies: 6Last Post: 15th Apr 2010, 09:37 -
Can I rip Blu Ray Discs with LG Super Multi Blu-ray Disc and HD DVD-ROM Dri
By donpato in forum Blu-ray RippingReplies: 5Last Post: 5th May 2008, 16:05
