What is considered the best tape stock for HDV? What's the best for the money? Thanks!
Results 1 to 16 of 16
Thread: HDV tape stock recommendations
Best for what? Sony Pro Master stock ... ~$16
http://www.tapestockonline.com/sodvdima40mi.html
best for the money?
Panasonic PQ series MiniDv ~$3 on sale (works fine in an HDV Sony HVR-Z1U or Canon HV20)
http://www.tapestockonline.com/pamidv.html
PS: For client material I generally use HDV Master quality tapes. They pay.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Thanks ed. I was getting a few dropouts with the DVC/EJ Series shooting DV on the GL2 (SP mode). You always shoot on SP?
SP always.
Do you see these dropouts in the camcorder monitor? Or just after transfer?
The latter could be other issues than tape.Recommends: Kiva.org - Loans that change lives.
Ya know, I was thinking that. My DV "deck" is an old beat up Elura2. Might it be a PC issue (also old and beat up). I checked the tape on on the GL2 and did not see a dropout. Please advise.
If it plays on the GL2 the tape is OK. Transfer from there.Originally Posted by kippard
It is always better to transfer MiniDV from the camcorder that recorded it if possible. The DVCAM format has wider track spacing to allow more reliable playback from a deck other than the recording camcorder. This limits recording time to 40min. Otherwise the formats are identical.
MiniDV LP mode (90min) records the same signal to narrower tracks than SP. This makes it very difficult to play on a deck other than the recording camcorder. LP should only be used in emercgency situations and never for archive.Recommends: Kiva.org - Loans that change lives.
Thanks for the info. ed.
I use Panasonic DVC Linear Plus 60 minutes DV tapes and they work very well in my Canon HV20.
Check out Panasonic AY DVM83PQ - Professional Quality - Mini DV tape - 10 x 83min at Amazon for a great price. I did.
What do you think of Panasonic PQ min-dv 83min tapes? If its 83 min of SP should be good right??
HV30+Wide Angle HD Lens, Rode Stereo Mic, Manfrotto Tripod System, Canon ZR 850
83min tapes are thinner than 63 min, or tigher packed in the cassette. They may have more aging issues.Originally Posted by Jensen
Further, AY-DVM63PQ (63 min) tapes are much cheaper.
http://www.tapestockonline.com/pan63minprof.htmlRecommends: Kiva.org - Loans that change lives.
Don't know how true it is, but it's been said that once you pick a specific tape you should stick with it and not change brands.
I've been using Sony DVC Premium tapes in my HVR-A1U and HDR-H1C without problem. You can get them at BJ's Wholesale Club for $24 for a ten pack.
I heard that, also - apparently, different tape stocks have different chemical coatings and mixing them can be harmful ones camera.Originally Posted by mrswla
lubricants, too
Author, Producer, Composer, Director - Sony HDV, Konica SLR, LG BD burner
Handcoder: HTML, PHP, JS, CSS - In Production: Busker Alley - The Movie
If one does have to change brands, what is the recommendation for any action to take with the camera? Some sort of cleaning prior to changing brands?
Thats what I was thinking....
Simple way to print HDV to tape
By stantheman1976 in forum EditingReplies: 6Last Post: 7th Aug 2011, 16:11 -
Retaining HDV scene split on tape?
By Undead Sega in forum Camcorders (DV/HDV/AVCHD)Replies: 0Last Post: 6th Oct 2010, 09:18 -
HDV player/recorders, recommendations?
By acej in forum Newbie / General discussionsReplies: 4Last Post: 3rd Dec 2009, 01:43 -
Can't capture from HDV tape!
By frlane in forum MediaReplies: 8Last Post: 2nd Jul 2009, 15:43 -
How much longer can tape-based HDV hang on?
By Ollie6431 in forum Newbie / General discussionsReplies: 18Last Post: 1st Feb 2008, 10:55
