When you use a video filter for widescreen it puts widescreen bars on the clip at an aspect ratio of 1.78:1 or 1.85:1, my question is can you make the aspect ration 2:1 or 2.35:1 in Final Cut?
If not, is there a way to edit on Final Cut Pro then make the widescreen changes or even put the bars at that aspect ratio in another program?
You may already have checked these out, but two great sources for Final Cut info are the Final Cut Pro forum at discussions.apple.com and www.kenstone.net
Color Correcting in Final Cut Pro 7 (probably an easy question to answer)
By Huntr777 in forum MacReplies: 0Last Post: 18th Apr 2010, 11:49 -
Final Cut Pro - Question about a skip in video, how to sync?
By Huntr777 in forum MacReplies: 0Last Post: 18th Oct 2009, 20:56 -
final cut pro - advanced question
By marinebc11 in forum MacReplies: 2Last Post: 18th Aug 2008, 10:01 -
Final Cut Pro Aspect Ratio Question
By Jeff_NJ in forum Newbie / General discussionsReplies: 0Last Post: 23rd Jul 2008, 10:25 -
final cut express and final cut pro 6
By ednarophati in forum MacReplies: 1Last Post: 16th Jul 2007, 10:05
Statistics
Newest guides
Latest tool updates
New media comments
