Hi,
I'm quite new to using GFD, so I haven't been able to get the PlayAll-button working?
When I try to insert the PlayAll-button and try to save it the program just says that "Action may not be empty", so what action should be set for the PlayAll to work?
I have tried with jump to title 1;, but then it behaves just like a normal title-button that jumps back to mainmenu after playing title 1!?
I saw somewhere that g0 or was it g2 should be used for that, but haven't had any results what those either...
Thank's for any help.
Micke from Finland
I do not really understand your problem...
If you add a 'Play all' button (by selecting 'Insert' - 'Play all button' from the GfD menu bar), the action is already prefixed with the (pseudo-)value 'Play_all'. No need to set up an own action.
How did you create the PlayAll-button?GUI for dvdauthor:
http://www.videohelp.com/~gfd/
Hi,
Now when I tried to make a new short project to show what it does, now it will add that action, but for my old project when I added it did just add the button without any action!
So I guess my old project is just simply somehow messed up, I will now try to recreate that project and see if it works!
Thank's anyway a lot for telling that there should be that pseudo-value play_all (that info I hadn't seen anywhere)!
Regards, Micke
Hi again,
Yes now it works also when I make new projects like the once that didn't work before, so this problem is solved, THANK'S!
Regards, Micke
Which to use, DVDAuthorgui or "GUI for dvdauthor" ? Or DVDauthor in batch ?
By halsboss in forum Authoring (DVD)Replies: 2Last Post: 1st Feb 2010, 11:00 -
Problem with GUI for dvdauthor
By DonStefano in forum Authoring (DVD)Replies: 12Last Post: 19th Feb 2009, 16:19 -
GUI for DVDAuthor Problem
By raygk in forum Authoring (DVD)Replies: 17Last Post: 1st Dec 2007, 12:39 -
GUI for DVDAuthor
By netbuddy in forum Authoring (DVD)Replies: 35Last Post: 15th Nov 2007, 05:12 -
gui for dvdauthor HELP
By dontpanic in forum Authoring (DVD)Replies: 10Last Post: 4th Aug 2007, 06:47
Statistics
Newest guides
Latest tool updates
New media comments
