VideoHelp.com Forum
    i want to purchase region 2 dvds from uk (ufc 9&10). I own a sony rdr gx330 dvd recorder and a Sharp AQUOS LC46D64U 46 inch 1080p tv. how do i make these type of dvds play on my setup. i also have a phillips hds3544 home theatre dvd player. if anyone can help, it would be greatly appriciated. thanx
  2. Member hech54's Avatar
    UK is PAL Format.
    USA is NTSC Format.
    Eliminating the region code problem
    still leaves you with the PAL/NTSC problem.
  3. Member Krispy Kritter's Avatar
    Assuming you have the HTS3544 and not the HDS3544 (which doesn't exist), there is a region free hack in the DVD Hacks section. I don't know how well that player handles the PAL to NTSC conversion, so don't be surprised if the quality isn't very good.
    On a side note, those editions will likely be released soon from the UFC (they are currently up to vol 8).
    Google is your Friend
  4. Greetings Supreme2k's Avatar
    FYI, only the admin can put any special formatting in the thread titles. You may want to edit the attempted formatting out of the title.
    If the region free hack works for you (usually Philips DVD players can be made region free, so you should be good here), go into the video setup and change the output from "Multi" or "Any" to "NTSC". Many HDTVs sold in the USA cannot correctly display PAL signals. Some can. Some can't. I don't know about your TV. Changing the video output on the DVD player to NTSC makes sure that your TV can display the signal.
    A more expensive DVD player like something from Oppo (http://www.oppodigital.com) will surely do a better job of PAL to NTSC conversion, but honestly the Philips may work good enough for you. If you don't like it, you can always buy an Oppo, which ship region free.
  1. Replies: 0
    Last Post: 21st Jul 2011, 13:30
  2. [color=blue]video oediting software for ASUS Eee PC (white ones)[/color]
    By helpmepls in forum Newbie / General discussions
    Last Post: 6th Feb 2009, 07:53
  3. How do you take red (or other color) out of every frame
    By deezin in forum Newbie / General discussions
    Last Post: 24th Jan 2009, 10:57
  4. [color=red]Huge annoying title[/color]
    By JohnnyMalaria in forum Test
    Last Post: 1st Feb 2008, 10:47
  5. [color=red]hd again[/color]
    By gunukhan in forum DVD & Blu-ray Players
    Last Post: 31st Jul 2007, 13:17
