VideoHelp.com Forum
Results 1 to 10 of 10
    I have a R-2 coded Sony DVP-NS78H DVD player.
    I bought a R-1 DVD and it happens that when I insert the DVD in the DVD player the following message appears: "the reproduction of this record is forbbiden by area limits".
    As such, I would like to know if it is possible for me to readily unlock my DVD player in order to be able to visualize R-1 DVDs along with R-2 ones and how to do it.
    Thank you.
  2. Member hech54's Avatar
    Not without MUCH work.
    http://www.videohelp.com/dvdhacks/sony-dvp-ns78h/8651
    Sony players are difficult to hack.
  3. Member mats.hogberg's Avatar
    Probably much easier to rip the DVD to DVD-R, as that process removes the regio code protection from the DVD.
    /Mats
    Thanks.
    I have seen that before but it seems too much complicated for me (I'm still a kind of ignorant on these matters).
    I'd really like to have my DVD player region free.
    Isn't there any other [simpler] way to unlock my DVD player besides the one you've linked?
    By the way, could you (or anyone) explain me what is a "winsamp-package" and a "PC IRDA port"?
    What do I need to have and what do I need to do to perform the "hack" you've linked?
  5. Member mats.hogberg's Avatar
    If there was, it'd probably be listed here, or easily found with a Google search.
    /Mats
  6. Mod Neophyte Super Moderator redwudz's Avatar
    Winsamp-package:
    This innovative piece of software allows you to send standard home electronics IR signals using a PC IRDA port.
    IrDA:
    Short for Infrared Data Association, a group of device manufacturers that developed a standard for transmitting data via infrared light waves. Increasingly, computers and other devices (such as printers) come with IrDA ports. This enables you to transfer data from one device to another without any cables. For example, if both your laptop computer and printer have IrDA ports, you can simply put your computer in front of the printer and output a document, without needing to connect the two with a cable.
    IrDA ports support roughly the same transmission rates as traditional parallel ports. The only restrictions on their use is that the two devices must be within a few feet of each other and there must be a clear line of sight between them.
    It sounds like you would either need a programmable infrared remote control or a PC with a IrDA port that can transmit the modification codes to the player.
    Warning - This can also permanently disable the player if done incorrectly.
    I think I would just rip the DVD and use something like DVD Shrink or DVD Rebuilder to create a region free disc.
  7. Member Krispy Kritter's Avatar
    Or if it is that important to have a region free player, buy a region free player.
    Google is your Friend
    Yes, I found the best solution for my case: I have just bought today a multiregion DVD player for only €50! And Sony should sell multiregion DVD players.
  9. Member mats.hogberg's Avatar
    Sony are one of the major forces behind such stupidities like region coding, so that'd be the day!
    /Mats
  10. Our Sony DVP-NS575P's inability to play anything except R1 NTSC led to its demotion to the family stereo system, where it performs admirably as a CD player. Bought an Oppo to feed the TV.
  1. SONY DVP-SR-500H, anyonw have any idea how to unlock it?
    By elonn in forum DVD & Blu-ray Players
    Last Post: 16th Nov 2010, 20:24
  2. sony dvd player dvp-ns67p without picture
    By kamran-ns67p in forum DVD & Blu-ray Players
    Last Post: 15th Aug 2010, 13:44
  3. Sony DVD player model DVP-NS78H region free hacking procedure
    By kanns in forum DVD & Blu-ray Players
    Last Post: 8th May 2010, 17:36
  4. My Sony DVD player SONY DVP- NS718 H
    By samyer in forum Newbie / General discussions
    Last Post: 2nd Feb 2010, 23:56
  5. Unlock for Sony DVP NS305, without a numbered remote or palmpilot/PC?
    By Jessminka in forum DVD & Blu-ray Players
    Last Post: 20th Sep 2007, 11:46
