VideoHelp.com Forum
    I have this Xvid (.avi) file. I created subtitles for it using Subtitle Workshop. Then I converted it to DVD using ConvertXtoDVD but the audio becomes too loud. I want to know if there is a way to convert the Xvid file to MPEG-2 manually and multiplex the DVD by hand. Or, is there a way to fix the audio bug of ConvertXtoDVD?
  2. Mod Neophyte Super Moderator redwudz's Avatar
    You can adjust the volume level in ConvertX. 'Settings>Audio'.
    Or you can encode the video and audio with a MPEG and a audio encoder, then use a authoring program to create the DVD structure. HC encoder and GUI for dvdauthor can do that. Or try the freeware FAVC. It's similar to ConvertX, but has a few more adjustments.
    I don't have an option for volume in Settings>Audio of ConvertX. I'm going to try the rest of the tools you mentioned.
    Have you upgraded to latest convertxtodvd?
    Oops! I'm using 2.1.6 and I have to upgrade
  1. DVD to XviD Conversion
    By DJRumpy in forum User guides
    Last Post: 7th Mar 2011, 16:37
  2. Replies: 1
    Last Post: 26th Feb 2010, 08:12
  3. Check Over My Options From DVD to XviD Conversion Thread
    By adalect in forum Newbie / General discussions
    Last Post: 9th Feb 2010, 20:24
  4. Ripped dvd conversion to xvid/divx weird audio problem
    By victoriabears in forum Video Conversion
    Last Post: 12th Feb 2009, 13:41
  5. dvd to xvid conversion problem
    By dominator007 in forum DVD Ripping
    Last Post: 19th Nov 2008, 15:33
