VideoHelp.com Forum
Results 1 to 9 of 9
    The new version of PS3 2.20 can show subtitles. But I can only play divx files with subtitles. I can't play mp4 files with subtitles. Can anybody help me?
    http://beans.seartipy.com/2008/01/11...ng-yambmp4box/
    Its actually just merging which the writer admits.
    Now if it works, you press triangle and select the subtitle option.
    Try "srt" subtitle's only
    Thanks. I will try.
    I have a question for you, how do you enable subs for Divx in PS3...I am unable to display subtitles with Divx videos...
    You can enable divx subtitle by AVIAddXSub on PS3. Search this program.
    Thanks for the response, but this is not what I meant. This program simply puts (integrates) the subtitle file into the video, so that's not the proper way to do it because this will play on all the divx capable players. Sony claims that FW 2.20 brings in the Divx Sub support. You don't need 2.20 to apply your solution.
    What I need to do is, have the SRT files (or any other sub file) loaded in PS3's media player seperately, not burnt into the video file.
  7. I'm a MEGA Super Moderator Baldrick's Avatar
    aviaddxsub makes switchable subtitles and not burned in.
    Have you tried AVIADDXSUB with bitmap subtitles idx/sub?
    It seems to work fine with text subtitles, srt, but it won't display anything when I use idx/sub.
    It finishes normally, and the player indicates there is a subtitle track which you can turn on/off.
    But no subtitle displays.
    this tutorial at http://dontcthis.com/2009/09/how-to-...ur-ps3-movies/ helped me with all of these problems.
  1. Ass subtitles. a mp4 hd file and a ps3.
    By ^.^hammy in forum Subtitle
    Last Post: 29th May 2010, 03:57
  2. PS3 or iPod MP4 subtitles supported?
    By Huh...What? in forum Subtitle
    Last Post: 9th Mar 2010, 12:20
  3. PS3 won't play some MP4 and AVI files
    By jiggy in forum Media Center PC / MediaCenters
    Last Post: 14th Feb 2010, 19:22
  4. How to edit mp4 files and play them on my PS3?
    By FlipUser in forum Video Conversion
    Last Post: 21st Oct 2009, 17:25
  5. Replies: 2
    Last Post: 19th Dec 2008, 14:12
