VideoHelp.com Forum
Thread: VHS restoration
    If a VHS cassette is re-recorded is there anyway to retrieve the original recording?
    I had an old family video on VHS and recently somebody recorded a T.V. show over it... Unfortunately that was my only copy and that video meant the world to me. Is there any way possible to retrieve the original recording? I will really appreciate any help. Thank you.
    Not unless you can unrecord the picture from the tape. Exactly the same as recording something else over an audio cassette
    Looks like you have lost it, the only hope you have is if the original wasn't recorded over entirely, so you might have some left
    Sorry, but thats why they use recording tabs, break the tab you can't 'accidentally' record over it again unless you cover the tab hole with tape to record again or the switch that stops that happening is broken .......
  3. Mod Neophyte Super Moderator redwudz's Avatar
    No way I have ever seen. That's why they put the tabs on VHS tapes, so you can block re-recording from happening. If the re-record is longer than the original video, it's all likely gone.
    And welcome to our forums.
  4. The Old One SatStorm's Avatar
    Only KIT from Knight Rider back in the 80s could do this
    I don't know any consumer way to restore a previous recording on a VHS tape. I read somewhere few years back, that through a very special and very expensive process, you may able to reconstruct something that looks like "shadows" of the previous recording.
  5. If you can build a flux capacitor attach to your car and drive 88 mph you will be able to go back in time before the point where you recorded over your tape, retrieve it and bring it back to the future. Basic common knowledge.
    Nope, no way to "undelete" analog recordings. May we suggest a call to Tony Soprano, who can have a little chat with the "somebody" who recorded over your tape without even asking you...
  1. VHS Restoration
    By Asesinato in forum Restoration
    Last Post: 25th Apr 2012, 21:11
  2. old vhs restoration
    By ishwinderjauhar in forum Restoration
    Last Post: 24th Sep 2011, 09:03
  3. old VHS restoration
    By pirej in forum Restoration
    Last Post: 8th Jun 2011, 09:19
  4. Some of my vhs restoration work
    By henryperu77 in forum Restoration
    Last Post: 23rd Apr 2011, 00:24
  5. VHS-C restoration
    By dlarry in forum Restoration
    Last Post: 25th Sep 2007, 21:14
