ok I have tried and tried to get his thing to work but with no success. It did work before so I do not know what happened. I have the HP dvd player and master adn a cd player as slave. I use Nero for burning . I am running XP sp2 . I can no longer play ANY commerical dvds or cds and can not play any dvd data that I have burnt with this . I can not find otu what is wrong or hwo to fix it can anyone help me out . I have tried the microsoft autofix and it didnt' work
Thanks Cassie
Thread: HP 840 dvd player problem
I checked the DMA status of both and are set correctly according to that tutorial. Any thing else I can try?
Thanks Cassie
It can't read any dvd or cd? Is the drive still recignized by Windows?
Try deleting the IDE channels. Goto Control Panel / System / Hardware / Device Manager / IDE ATA/ATAPI controllers ...and then remove/delete the primary and secondary IDE channels. Then reboot. Windows will automatically install the drivers and find all of the drives when it boots.Google is your Friend
Yes it is recognized by windows it gives me the error that I need to insert a disc is I put in a commercial dvd or cd
Need help merging 720p intro + 840*524 Fraps footage
By Reggaesmurf in forum Video ConversionReplies: 0Last Post: 16th Mar 2011, 03:12 -
DVD player or TV problem??
By okyup in forum DVD & Blu-ray PlayersReplies: 7Last Post: 5th Jan 2009, 14:03 -
DVD player problem
By WuPhilly in forum Newbie / General discussionsReplies: 1Last Post: 3rd Jul 2008, 00:27 -
Sony DRu 840 dvd RW Tray won't stay closed
By scustalow in forum ComputerReplies: 1Last Post: 30th Apr 2008, 11:39 -
Problem with pc dvd player
By Reds in forum DVD & Blu-ray PlayersReplies: 4Last Post: 8th Feb 2008, 09:47
