VideoHelp.com Forum
    I ripped a double layer disc to my hard drive, and the only blank media i have is single layer discs. Is there any software that will let me shrink and burn the ripped folder to DVD at the same time the way NERO does on Windows? I have Toast, but it doesnt let me shrink them. thanks in advance
  2. Mod Neophyte Super Moderator redwudz's Avatar
    You would likely get more answers to Mac specific questions in our Mac Forum. Moving you.
    And welcome to our forums.
    EDIT: You might look to this post and others here in this forum: http://forum.videohelp.com/topic342778.html
  3. Member terryj's Avatar
    STF for Mac The Ripper, or albloom, who seems to post the link to the answer
    to this question every other week.
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
    You say you have Toast. If it is version 7, 8 or 9 they all have the fit-to-DVD compression to burn a dual-layer-sized VIDEO_TS folder to a single layer disc. So you may be able to do it with what you have.
    Use MacTheRipper 3.0R14M to rip.
    DVD2oneX 2.1.4 to run the ripped Video_TS files through (Full Disc or Movie Only) to fix mastering errors and to compress if you are using SL dics.
    I like the compression of DVD2oneX better then Toast but then again I just do movie only with DVD2oneX anymore.
    You can burn with DVD2oneX 2.1.4 also or use Toast to burn with.
    As you might gather, it is useful to give the names and version
    numbers of the apps in these postings.
    It'll help with diagnosis of your problems.
    Al Bloom
  1. Replies: 2
    Last Post: 3rd Nov 2010, 22:05
  2. Compressing .vob or .ifo files using DVD Shrink
    By hostofsorrow in forum Authoring (DVD)
    Last Post: 21st Jan 2010, 22:19
  3. Replies: 7
    Last Post: 21st Oct 2008, 19:10
  4. Need to compress 5 VOB files to fit in one 4.7GB DVD...
    By pmolson in forum Video Conversion
    Last Post: 20th Oct 2008, 17:52
  5. Replies: 3
    Last Post: 28th Sep 2007, 15:04
