VideoHelp.com Forum
Results 1 to 10 of 10
    Alrighty. Here's what I did.
    I got a video (A) from Youtube. It plays fine with various media players. I used FLVExtract to separate it into its FLV (B) and MP3 (C) components, both of which play fine. I've got a new MP3 (D) of precisely the same duration which I want to mux back into the audio-less FLV (B) I generated with FLVExtract.
    I tried this command with ffmpeg:
    ffmpeg -i B.avi -i D.mp3 E.flv
    Ffmpeg properly recognized B.avi as an FLV file, and D.mp3 as an mp3. It generated E.flv. But it reencoded the data, and the result is highly degraded in quality. In order to overcome this, I then tried:
    ffmpeg -i B.avi -i D.mp3 -vcodec copy -acodec copy E.flv
    This time, ffmpeg was kind enough to fail, informing me that, "error, non monotone timestamps 13 >= 0". I'm quite fuzzy on what this means. But some hunting revealed that Mencoder should be able to generate timestamps without re-encoding. Accordingly, I tried this:
    mencoder B.avi -ovc copy -D.mp3 -oac copy -o E.flv
    This seemed to work, but I got a little suspicious when the output file was actually a hair smaller than the video component (never mind the combined size of video and audio). Sure enough, nothing could play the E.flv Mencoder had generated.
    Anyway, that's all I'm trying to do. Combine the FLV video with the MP3 audio without reencoding. They're both the same duration. The MP3 is a CBR with nothing fancy. Should I be using something else? Some other command line?
    Thanks. ;p
  2. Get Slack disturbed1's Avatar
    ffmpeg -i blah.avi -i blah.mp3 -vcodec copy -acodec copy out.flv
    Linux _is_ user-friendly. It is not ignorant-friendly and idiot-friendly.
    That's one that I tried. Ffmpeg failed (see above). Hoping there's a solution.
  4. Get Slack disturbed1's Avatar
    ffmpeg doesn't fail with the non-mono tone errors. It's just informing you your source files weren't created correctly. There should be a different error message at the end to preclude what the problems is. Considering both mencoder and ffmpeg fail to do a simple copy of streams, suggests the streams are at fault?
    Why don't you use ffmpeg to process the original flv and just add a new audio file to it? -newaudio
    http://ffdshow.faireal.net/mirror/ffmpeg/
    Use rev.10464 from here.
    you can also try the last build, but i've found it crashes.
    (and btw if you want to use a ffmpeg gui check Avanti)
    with mencoder you have to specify the lavf muxer
    insert into the commandline:
    -of lavf
    tripp
    In moderate desperation, I've been trying just that.
    ffmpeg -i A.flv -i B.wav -ab 96 E.flv
    It processes the original flv alright, but it ignores the wav file and uses the original flv's audio. Furthermore, any attempt I make to undertake the - let's face it - convoluted process for 2-pass encoding fails utterly. Usually I get a complaint about not being to scale an "unsupported format", which strikes me as perhaps an inaccurate assessment.
    But before I move on to the grandiose achievement of 2-pass encoding, I'd better figure out why I can't get ffmpeg to use video from A, audio from B, and generate C. Or, rather, see if anyone's used the program enough to be able to intuit what I'm doing wrong. ;p
  7. Get Slack disturbed1's Avatar
    Did you try
    -newaudio?
    Or -
    ffmpeg -i in.flv -an out.flv
    (-an I call it short for audio no, it disables audio encoding)
    ffmpeg -i out.flv -i audio.mp3 -vcodec copy -acodec copy new.flv
    Here's the last quandry I am dealing with. I cannot get ffmpeg to encode a wav file. Not by itself (with -vn), and not as the audio component merged with a flv which it created. It recognizes the wav as audio. The wav is the same duration as the flv. Here is what it says:
    ffmpeg.exe -i trying.wav -vn -ab 96kb blah1.mp3
    Input #0, wav, from 'trying.wav':
    Duration: 00:05:29.2, bitrate: 2822 kb/s
    Stream #0.0: Audio: 0x003, 44100 Hz, stereo, 2822 kb/s
    Output #0, mp3, to 'blah1.mp3':
    Stream #0.0: Audio: libmp3lame, 44100 Hz, stereo, 96 kb/s
    Stream mapping:
    Stream #0.0 -> #0.0
    Unsupported codec (id=0) for input stream #0.0
    I have tried three different ffmpegs and they all say the same thing. I have also tried getting ffmpeg to combine the flv (which, again, it created) with an mp3 made from the wav with Adobe Audition, CBR so nothing fancy, and that's when it instead decides there are timestamp issues and doesn't work.
    Maybe there needs to be a front-end for ffmpeg, called "Ffmpeg baby" or something, whose sole purpose is to ensure that the hygiene of the input files aren't going to generate ambiguous failure messages.
  9. Banned
    That means a 32-bit audio file.
    HTH.
    Okay. Thanks. That fixed that hurdle. I stand by what I said about ambiguous error messages, though. ;p
    "Ffmpeg Baby says, 'Ffmpeg doesn't like 32-bit audio - shall I convert the file for you now? [No!] [Yes] [Yes to all (Do whatever; just make it happy)]"
  1. Replies: 3
    Last Post: 7th Oct 2010, 15:23
  2. .avi -> .flv with embedded subtitles using MENCODER
    By the_provider in forum Video Conversion
    Last Post: 28th Oct 2009, 16:38
  3. Mencoder // ffmpeg flv file Audio-video sync problem
    By krishnareddy in forum ffmpegX general discussion
    Last Post: 26th Apr 2009, 09:13
  4. Replies: 0
    Last Post: 26th Mar 2008, 15:39
  5. AVI to FLV using mencoder
    By Riotblade in forum Video Conversion
    Last Post: 13th Feb 2008, 12:00
