VideoHelp.com Forum
    Hi!
    I'm trying to make a DVD with subtitles using spumux and dvdauthor. It is just a small test clip (30 seconds) with 4 subtitles to speed things up while I'm learning. The DVD does not have to have any menus or anything. I muxed the subtitles in the mpeg using spumux with the following xml file:
    <subpictures>
          <stream>
            <textsub filename="mummy1.srt" characterset="UTF-8"
                 fontsize="24.0" font="devedesans.ttf" horizontal-alignment="center"
                 vertical-alignment="bottom" left-margin="60" right-margin="60"
                 top-margin="20" bottom-margin="30" subtitle-fps="25"
                 movie-fps="25" movie-width="720" movie-height="576"
    	     force="yes"/>
          </stream>
    </subpictures>
    and then ran the spumux command. That went like this:
    [~/DVDTEST] $ spumux -s0 mummy1.xml < mummy1.mpg > mummy1_SUBBED.mpg
    DVDAuthor::spumux, version 0.6.14.
    Build options: gnugetopt iconv freetype fribidi
    Send bugs to <dvdauthor-users@lists.sourceforge.net>
    INFO: Locale=en_US.UTF-8
    INFO: Converting filenames to UTF-8
    INFO: Detected subtitle file format: subviewer
    INFO: Opened iconv descriptor. *UTF-8* *UTF-8*
    INFO: Read 4 subtitles
    INFO: Adjusted 2 subtitle(s).
    INFO: Unicode font: 2802 glyphs.
    INFO: Found EOF in .sub file.
    INFO: 4 subtitles added, 0 subtitles skipped, stream: 32, offset: 0.16
    Statistics:
    - Processed 4 subtitles.
    - The longest display line had 45 characters.
    - The maximum number of displayed lines was 2.
    - The normal display height of the font devedesans.ttf was 26.
    - The bottom display height of the font devedesans.ttf was 48.
    - The biggest subtitle box had 2150 bytes.
    [~/DVDTEST] $
    Now, when I spuunmux the resulting file (mummy1_SUBBED.mpg), I get the subtitles in png format, so I know they're in there. But after using dvdauthor to create the dvd, when I play it, no subtitle options are available in either mplayer or vlc (both would usually handle subs fine).
    The dvdauthor commands I tried went like this:
    [~/DVDTEST] $ dvdauthor -t mummy1_SUBBED.mpg -o TEST
    DVDAuthor::dvdauthor, version 0.6.14.
    INFO: dvdauthor creating VTS
    STAT: Picking VTS 02
    STAT: Processing mummy1_SUBBED.mpg...
    STAT: VOBU 64 at 19MB, 1 PGCS
    INFO: Video pts = 0.160 .. 32.120
    INFO: Audio[0] pts = 0.160 .. 31.968
    INFO: Audio[32] pts = 3.960 .. 18.961
    STAT: VOBU 68 at 20MB, 1 PGCS
    INFO: Generating VTS with the following video attributes:
    INFO: MPEG version: mpeg2
    INFO: TV standard: pal
    INFO: Aspect ratio: 4:3
    INFO: Resolution: 720x576
    INFO: Audio ch 0 format: ac3/6ch, 48khz drc
    STAT: fixed 68 VOBUS
    [~/DVDTEST] $ dvdauthor -T -o TEST
    INFO: dvdauthor creating table of contents
    INFO: Scanning TEST/VIDEO_TS/VTS_01_0.IFO
    INFO: Scanning TEST/VIDEO_TS/VTS_02_0.IFO
    [~/DVDTEST] $
    but I also tried it with -s "en" added to the first command. Also I tried with a simple xml file:
    <dvdauthor dest="TEST">
       <vmgm />
       <titleset>
         <titles>
           <video format="pal" aspect="4:3"/>
           <subpicture lang="en" />
           <pgc>
             <vob file="mummy1_SUBBED.mpg"/>
           </pgc>
         </titles>
       </titleset>
     </dvdauthor>
    All produce the same result. No subtitles. What am I doing wrong?
    thanks,
    bepaald
  2. Get Slack disturbed1's Avatar
    Why is dvdauthor creating 2 VTS's if there is only one title?
    Make sure your directory is empty, running dvdauthor with the -t option just adds another title to the next available VTS. If there is already a dvd structure in the output directory, dvdauthor adds to it.
    Run mplayer from the command line with mplayer -dvd-device /path/VIDEO_TS dvd://1
    Watch the output on the command line, it gives good info. Could try lsdvd -s /path/to/dvd/folders
    Since spumux and spuunmux completed without error, it sounds like perhaps an authoring issue, or player issue. The xml and output of dvdauthor looks correct other than INFO: dvdauthor creating VTS STAT: Picking VTS 02
    Linux _is_ user-friendly. It is not ignorant-friendly and idiot-friendly.
    First of all thanks for replying!
    The VTS 02 was my fault I'm afraid. To get the output to copy in my first post I ran the commands again without first deleting the TEST directory. But the results are the same. I'd post the output again, but it's nearly identical (it says 'STAT: Picking VTS 01' now).
    mplayer's output:
    [~/DVDTEST] $ mplayer -dvd-device TEST/VIDEO_TS/ dvd://1
    MPlayer 1.0rc2-4.1.2 (C) 2000-2007 MPlayer Team
    CPU: Intel(R) Core(TM)2 CPU          6400  @ 2.13GHz (Family: 6, Model: 15, Stepping: 2)
    CPUflags:  MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1
    Compiled with runtime CPU detection.
    Playing dvd://1.
    There are 1 titles on this DVD.
    There are 1 chapters in this DVD title.
    There are 1 angles in this DVD title.
    number of audio channels on disk: 0.
    number of subtitles on disk: 0
    MPEG-PS file format detected.
    VIDEO:  MPEG2  720x576  (aspect 2)  25.000 fps  9800.0 kbps (1225.0 kbyte/s)
    Opening video decoder: [mpegpes] MPEG 1/2 Video passthrough
    VDec: vo config request - 720 x 576 (preferred colorspace: Mpeg PES)
    Could not find matching colorspace - retrying with -vf scale...
    Opening video filter: [scale]
    The selected video_out device is incompatible with this codec.
    Try appending the scale filter to your filter list,
    e.g. -vf spp,scale instead of -vf spp.
    VDecoder init failed :(
    Opening video decoder: [libmpeg2] MPEG 1/2 Video decoder libmpeg2-v0.4.0b
    Selected video codec: [mpeg12] vfm: libmpeg2 (MPEG-1 or 2 (libmpeg2))
    Opening audio decoder: [liba52] AC3 decoding with liba52
    Using SSE optimized IMDCT transform
    Using MMX optimized resampler
    AUDIO: 48000 Hz, 2 ch, s16le, 384.0 kbit/25.00% (ratio: 48000->192000)
    Selected audio codec: [a52] afm: liba52 (AC3-liba52)
    AO: [alsa] 48000Hz 2ch s16le (2 bytes per sample)
    Starting playback...
    VDec: vo config request - 720 x 576 (preferred colorspace: Planar YV12)
    VDec: using Planar YV12 as output csp (no 0)
    Movie-Aspect is 1.33:1 - prescaling to correct movie aspect.
    VO: [xv] 720x576 => 768x576 Planar YV12
    A:  11.0 V:  11.0 A-V: -0.006 ct:  0.094 275/275  7%  0%  1.1% 1 0
    Exiting... (Quit)
    [~/DVDTEST] $
    The important part of that output is probably the 'number of subtitles on disk: 0' line. However lsdvd (I didn't know about that program, thanks), gives:
    [~/DVDTEST] $ lsdvd TEST/
    Couldn't read enough bytes for title.
    Disc Title: unknown
    Title: 01, Length: 00:00:31.180 Chapters: 01, Cells: 01, Audio streams: 01, Subpictures: 01
    Longest track: 01
    [~/DVDTEST] $
    Not sure if the first line of output is anything to worry about, but it does say there are subtitles. Any more ideas, or should I maybe just burn it and see if it works on a standalone player?
    bepaald
    *EDIT*
    I just mkisofs'd the output directory, mounted the iso and then I could select the subtitles in videolan. Not in mplayer though, and in videolan the subs weren't forced like I'd wanted.
  4. Get Slack disturbed1's Avatar
    I figured it was a player issue. Mplayer can be picky with many things that aren't simple *.avi, *.mpg.... The bug list is long on it, but what it does do, it does well.
    You can put this in $HOME/.gnome2/nautalis-scripts Any folder you right click on and choose to do so, will play as a dvd. Beats mkisofs, mount ...
    #!/bin/sh
    #vlc.dvd play
    vlc dvd://$1
    Don't forget to chmod +x I actually have that script in /usr/bin and associated with *.img files, and an open with option on folders.
    Read this for forced subs.
    http://www.floatinginspace.za.org/spumux/subtitles.html
    Hi!
    I have no more problems now, I added several more subs and made a nice menu to be able to choose between them. Everything is working great, I just wanted to say thanks for the help.
    So thanks!
    bepaald
  6. Get Slack disturbed1's Avatar
    Originally Posted by bepaald
    Hi!
    So thanks!
    bepaald
    Ummmmmmmm.... you're welcome
    You did all the work. I just posted lsdvd
  1. Too many PCGs? DVDAuthor errors
    By lefty.crupps in forum Authoring (DVD)
    Last Post: 26th Nov 2008, 02:45
  2. svcd preview errors & vob file errors
    By kiwi76 in forum SVCD2DVD & VOB2MPG
    Last Post: 10th Nov 2008, 16:02
  3. Full conversion MKV subs to avi subs & fonts intact.
    By ashidosai in forum Video Conversion
    Last Post: 18th Oct 2008, 16:36
  4. Strange (IMHO) errors with GUI for dvdauthor
    By Ego Tripper in forum Authoring (DVD)
    Last Post: 4th Feb 2008, 16:33
  5. Replies: 1
    Last Post: 1st Jan 2008, 14:33
