Hi,
I was wondering if anyone has ran into this problem before. I get an error that basically messes up the audio of the transcoded video. This is the error I am getting:
faac: frame decoding failed: Array index out of range Error while decoding stream #0.0
Does this generally happen if the source is prepared as a streaming video rather than a progressive download video?
The following is portion of the log:
FFmpeg version SVN-r12223, Copyright (c) 2000-2008 Fabrice Bellard, et al.
configuration: --enable-gpl --enable-pp --enable-libvorbis --enable-liba52 --enable-libmp3lame --enable-libfaad --enable-libfaac --prefix=/usr
libavutil version: 49.6.0
libavcodec version: 51.50.1
libavformat version: 52.7.0
libavdevice version: 52.0.0
built on Feb 26 2008 00:00:29, gcc: 3.4.6 20060404 (Red Hat 3.4.6-9)
[mov,mp4,m4a,3gp,3g2,mj2 @ 0x8358340]edit list not starting at 0, a/v desync might occur, patch welcome
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/usr/local/websites/goodtube.org/converter/223':
Duration: 00:07:40.1, start: 0.000000, bitrate: 1462 kb/s
Stream #0.0(eng): Audio: mpeg4aac, 32000 Hz, stereo
Stream #0.1(eng): Video: h264, yuv420p, 640x480 [PAR 0:1 DAR 0:1], 29.97 tb(r)
Stream #0.2(eng): Data: rtp / 0x20707472
Stream #0.3(eng): Data: rtp / 0x20707472
Output #0, flv, to '/usr/local/websites/goodtube.org/videos/223.flv':
Stream #0.0(eng): Video: flv, yuv420p, 440x330 [PAR 0:1 DAR 0:1], q=2-31, pass 1, 800 kb/s, 29.97 tb(c)
Stream #0.1(eng): Audio: libmp3lame, 44100 Hz, mono, 96 kb/s
Stream mapping:
Stream #0.1 -> #0.0
Stream #0.0 -> #0.1
Press [q] to stop encoding
[mpeg4aac @ 0x840bd10]faac: frame decoding failed: Array index out of range
TIA
Thread: ffmpeg faac frame decode failed
I've never had good luck decoding aac with ffmpeg. The best utility I've found for that purpose is called FAAD . Convert the output to WAV, or pipe the output back into ffmpeg. You'll have some syntax experimentation ahead of you, but it'll probably work better than ffmpeg alone.
Here is a GUI for faad called Ivan & Menno. It is just a GUI so you will have to download faad seperatly from rarewares.org
Donadagohvi (Cherokee for "Until we meet again")
My Video Tools :: Free Security Software :: Ubuntu Antivirus Rescue CD
Virtualdub Error Message - Failed to load FFmpeg.dll
By SOSmkII in forum Video ConversionReplies: 5Last Post: 6th Feb 2012, 07:14 -
how to use ffmpeg to encrypt both the i-frame and p-frame?
By shredding in forum ProgrammingReplies: 2Last Post: 12th Jan 2012, 12:53 -
faac: frame decoding failed: Gain control not yet implemented
By vthirteen in forum ffmpegX general discussionReplies: 1Last Post: 2nd Jun 2010, 13:16 -
ffmpeg 50Mps I-frame only for mpeg2-cards?
By jonar in forum Video ConversionReplies: 5Last Post: 14th Oct 2009, 03:53 -
FFMPEG QUESTION :How do I take one frame and make a jpeg with FFMPEG?
By goheadtry in forum Newbie / General discussionsReplies: 1Last Post: 18th Sep 2007, 02:55
Statistics
Newest guides
Latest tool updates
New media comments
