VideoHelp.com Forum
  1. Banned
    Plz tell me will the on board sound card enough for DVD authorizing. Or will the on board sound card create sync problems
    Sound cards are not utilized for DVD authoring
  3. Mod Neophyte Super Moderator redwudz's Avatar
    Just to add, you wouldn't have sync problems when just authoring anyway. Those are more common with encoding or capturing. Authoring is only the process of creating the DVD structure. The MPEG files are not altered, just rearranged. Some authoring programs can re-encode and that might cause problems, but if the file needs re-encoding, you already have a problem.
    Or, if you are asking about capturing video while separately feeding the audio into a sound card to be recombined with the video at some point, then you can create sync problems. But whether you used a on-board or PCI audio card, those problems would usually be the same.
  1. Replies: 0
    Last Post: 19th Jan 2012, 21:03
  2. [VHS conversion] Sound Card, Video Card?
    By bessiecat in forum Capturing
    Last Post: 26th May 2011, 13:02
  3. Replies: 0
    Last Post: 21st May 2010, 14:44
  4. Replies: 9
    Last Post: 14th Aug 2009, 16:13
  5. How do I overclock Intel 945G on-board video card?
    By oleglelchuk in forum Newbie / General discussions
    Last Post: 13th May 2008, 21:48
