Hello everyone,
Longtime lurker, first time poster. I just built a new system, quick rundown of specs...
WinXP Home SP2
3.2 Ghz AMD Athlon 64 x2
Asus M2N-SLI Deluxe NVidia nForce 570 SLI
2 - MSI GEForce 8500GT 256MB cards running SLI
4 GB DDR2 RAM
1 - 300 GB HD (running Windows)
1 - 750 GB HD
1- 400 GB HD
2 Lite-On Sata LH-20A1L-06 DVD Burners
12 USB 2.0 ports, 4 Firewire, Sata etc.
I have another system running Pinnacle Studio 9 and 11 with a MovieBox Deluxe and it works perfectly, but it is an Intel system. I tried installing everything on the new AMD system and it will just not work right. Video preview freezes, capture freezes, preview turns black and white, all kinds of problems. I am thinking it is a hardware conflict so I need a new device.
What do you guys recommend with my system specs? I mainly capture digital cable and some VHS through VCR using S-video and RCA's. In the future, I was thinking of the BlackMagic Card with HDMI but right now I could use a cheaper solution.
I would appreciate your help.
Thanks!
That system shouldn't have any problems with standard definition video. You have some kind of hardware conflict or driver/software problem. Be sure to update all your motherboard hardware drivers and your graphics card drivers. Make sure all your drives are running in DMA mode.
Yeah that is what I was thinking. I updated all the drivers and checked the DMA settings, all of that is good but it still does not work.Originally Posted by jagabo
I have a ASUS Mother Board "M2N-E" with a AMD 64 Athlon X2 processor
has two Memory Chips in it, two 2 gig chips = 4 gig in two of the four slots
what I want to do is to hook up a old VCR so I can edit the video
then put it on DVD.
I have Windows xp Professional x64 Edition.(64 bit)
Please give me some idea of what kind of
you recomend to make this work.
I need a video capture card and video edit software that will work with Windows xp Professional x64 Edition.(64 bit)
post your input , or helpful ideas on this.
(64 bit) is the Problim no one suports it.
thank you
freejoe
I see that this is your first post..well..welcome.Originally Posted by freejoe
Sorry to tell you that you got off on the wrong foot.
You should start a new thread with your question and
not post it in someone else's thread. Just try it.
That's only one strike
PS3, HDMI Splitter, Video Capture Device or Card, Ambilight, ADVICE!
By NexusSIX1976 in forum CapturingReplies: 5Last Post: 16th Oct 2011, 20:38 -
Need a recommendation on a new capture card/device
By MJDore in forum CapturingReplies: 1Last Post: 14th Oct 2011, 15:56 -
Advice on a direct capture device from MiniDV cam.
By nomeite in forum CapturingReplies: 5Last Post: 29th Oct 2010, 09:43 -
Need advice, looking for a USB Tuner/Capture Device that will work in OS X
By jrru2 in forum CapturingReplies: 2Last Post: 23rd Oct 2010, 19:06 -
I Have Nero 7 Ultra but Need Video Capture Device Recommendation
By Classic '57 in forum Newbie / General discussionsReplies: 2Last Post: 12th May 2009, 17:45
